10-12-2014, 05:05 | #1 (permalink) |
Junior Member Join Date: Oct 2014
Member: 2272501 Status: Offline Thanks Meter: 1 | iphone 5 - replaced screen without dissassembly battery I'm very new in this world. I hope this forum will help me. I made a big mistake, I replace an iphone 5 display without removing the battery. The result is obviously a black screen turning the iphone on. I wanna know if I damaged only the display or some component on the motherboard ? I just order a new display. Can I will see the iphone working replacing the display with the new one ? I heard also that some display have some metal exposed and isolating them probably it will work. This is right ? How can I test the display corrupted ? I just bought a text display flex cable by I have not idea how it works. Thanks in advance for any help, Brunix |
The Following User Says Thank You to brunix70 For This Useful Post: |
10-12-2014, 06:41 | #2 (permalink) |
Banned Join Date: Oct 2014 Location: india ( Punjab )
Member: 2271772 Status: Offline Sonork: 100.1672706 Thanks Meter: 45 | FIRST TRY TO CHANGE THE DISPLAY AFTER CHANGE THE DISPLAY IF RESULT IS OK THEN FINE IF NO THEN SO HARDWARE ISSUE BETTER CONTACT TO IPHONE HARDWARE EXPERT IF U ARE NEW THEN MEANS U CAN FACE SOME MORE PROBLEMS DURING THIS Thanks |
10-13-2014, 13:52 | #8 (permalink) |
Freak Poster Join Date: Jan 2013 Location: Switzerland Age: 48
Member: 1873863 Status: Offline Thanks Meter: 67 | Friend you need to check and then evenually replace FL24 , it break when you connect lcd without disconnecting battery. FL24.JPG |
The Following User Says Thank You to laptopmd For This Useful Post: |
10-13-2014, 15:15 | #9 (permalink) | |
Member: 2272501 Status: Offline Thanks Meter: 1 | Quote:
Thanks in advance, B. | |
