Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 09-27-2013, 09:45   #1 (permalink)
Member: 245360
Thanks Meter: 3
iphone 5 short after waterdamage
hi all,
i have water damage iphone 5. short circuit shows all devices (1-4 Pin is short) What is the solution
Old 02-16-2015, 23:21   #2 (permalink)
dragosgsm's Avatar
Member: 148032
Thanks Meter: 415
same problem here, any solution ?
Old 02-17-2015, 04:12   #3 (permalink)
Member: 1668980
Thanks Meter: 35
Hi
I have revived a few iphones doing this way
remove the heat shield form motherboard, clean the board with isapol alcahol, then check if still short if so
connect an external power source to the two pins that is short 3.7V
and wait till any compenent heats up and then remove the component that is hot
usually a capacitor.
good luck
Old 02-17-2015, 13:35   #4 (permalink)
Member: 1742913
Sonork: 100.1604070
Thanks Meter: 328
today i repired short motherbord mayb help u
Old 02-26-2015, 23:58   #5 (permalink)
Member: 2344322
Thanks Meter: 2
I have the same problem, pin 1 and 4 short on battery connection.
Android unbrik do you have a bigger picture ?
Old 02-27-2015, 00:57   #6 (permalink)
Member: 747693
Thanks Meter: 5
You need to work out what component is shorted yourself! just because one guy replaced a capacitor doesn't mean it works for you too!
Old 02-27-2015, 10:21   #7 (permalink)
Member: 2344322
Thanks Meter: 2
And what is the best way to do it, where do i start ?
Someone here told that you have to use a external dc source to power the board so you can find the component that gets hot ?
Old 02-27-2015, 12:11   #8 (permalink)
Member: 747693
Thanks Meter: 5
That would be a good place to start, applying low voltage high current will cause to shorted component to carry all the load and therefore heat or burn giving you a visual clue. Also symptoms will help you narrow down areas to look for example, touch issues could be a short in the touch IC or supplying components etc, get hold of the schematics and trace the lines.
Old 02-27-2015, 15:17   #9 (permalink)
Member: 2344322
Thanks Meter: 2
And what is a safe low voltage to use without damaging the board.
Old 02-27-2015, 15:51   #10 (permalink)
Member: 747693
Thanks Meter: 5
well the maximum the battery outputs is 4.2v
Old 06-30-2015, 14:05   #11 (permalink)
Member: 322417
Thanks Meter: 940
Originally Posted by calais250 View Post
Hi
good luck
Which alligators you use to connect external power supply to battery connector on iphone 5?
Old 08-26-2015, 08:30   #12 (permalink)
Member: 2330510
Hi,
gsmhosting is awesome.
I find this post relevant, trying to repair a few of my phones to pass some time.
Measured across pins to find about 11k ohms so im thinking there is a short.
I apply a small voltage across those same pins and wait till its hot?
i have a small dc voltage regulator, am i correct , by connecting both positive and negative to the positive and negative terminals on the batt connector?
any tips would be appreciated
Thanks
Old 08-28-2015, 04:40   #13 (permalink)
Member: 1668980
Thanks Meter: 35
I solder a tiny wire to the cap then use aligator clip
Page generated in 0.24920 seconds with 8 queries
