02-17-2015, 04:12 | #3 (permalink) |
Freak Poster Join Date: Oct 2011
Member: 1668980 Status: Offline Thanks Meter: 35 | Hi I have revived a few iphones doing this way remove the heat shield form motherboard, clean the board with isapol alcahol, then check if still short if so connect an external power source to the two pins that is short 3.7V and wait till any compenent heats up and then remove the component that is hot usually a capacitor. good luck |
02-27-2015, 10:21 | #7 (permalink) |
Junior Member Join Date: Feb 2015
Member: 2344322 Status: Offline Thanks Meter: 2 | And what is the best way to do it, where do i start ? Someone here told that you have to use a external dc source to power the board so you can find the component that gets hot ? |
02-27-2015, 12:11 | #8 (permalink) |
Junior Member Join Date: Apr 2008
Member: 747693 Status: Offline Thanks Meter: 5 | That would be a good place to start, applying low voltage high current will cause to shorted component to carry all the load and therefore heat or burn giving you a visual clue. Also symptoms will help you narrow down areas to look for example, touch issues could be a short in the touch IC or supplying components etc, get hold of the schematics and trace the lines. |
06-30-2015, 14:05 | #11 (permalink) | |
Banned Join Date: Jul 2006 Location: dword ptr [ebp-1C], edx
Member: 322417 Status: Offline Thanks Meter: 940 | Quote:
08-26-2015, 08:30 | #12 (permalink) |
Junior Member Join Date: Jan 2015
Member: 2330510 Status: Offline Thanks Meter: 0 | Hi, gsmhosting is awesome. I find this post relevant, trying to repair a few of my phones to pass some time. Measured across pins to find about 11k ohms so im thinking there is a short. I apply a small voltage across those same pins and wait till its hot? i have a small dc voltage regulator, am i correct , by connecting both positive and negative to the positive and negative terminals on the batt connector? any tips would be appreciated Thanks |
