05-19-2015, 20:28 | #1 (permalink) |
Junior Member Join Date: May 2014
Member: 2194770 Status: Offline Thanks Meter: 9 | Iphone 5 short between positive and negative I have one iphone 5 who have a short between positive and negative connections battery. It happened after a little little little water damaged. The board is clean, so, how can i find the short please ? Thanks |
05-20-2015, 00:24 | #2 (permalink) |
Freak Poster Join Date: May 2015 Location: Ireland Age: 51
Member: 2393796 Status: Offline Thanks Meter: 10 | Might be where it gets very hot, can use electronics freeze spray to see which defrosts first, or test around where water was spilt, probably under a chip where you cannot see, has dried sulphur type corrosion connecting positive negative together making a short. |
05-20-2015, 11:03 | #3 (permalink) |
Insane Poster Join Date: Oct 2007
Member: 617567 Status: Offline Thanks Meter: 6 | Finding full short its not so difficult, start by removing coroded capacitors in batt vcc line, and if you still cant find , connect to power and see which element heats up first. |
05-21-2015, 23:35 | #5 (permalink) |
Junior Member Join Date: Apr 2015
Member: 2386814 Status: Offline Sonork: [email protected] Thanks Meter: 0 | s3 null problem solution please send |
