09-12-2014, 23:49 | #1 (permalink) |
Junior Member Join Date: Sep 2014
Member: 2256764 Status: Offline Thanks Meter: 0 | Iphone 5 U2 ic 3 Prints broken |
09-13-2014, 22:53 | #3 (permalink) |
Freak Poster Join Date: Jun 2014
Member: 2205919 Status: Offline Thanks Meter: 33 | which pads are broken? there is easy way to fix… if these pads are in center u2 you have gently do a little hole until you will see rest of ways… put some flux and little slder. that's it. If this pad is near to edge you have to do a jumper with some thin wire… i repair a lot of broken pads in u2 always success. Tell me which pads, maybe you don't have to reapir all of it. |
The Following User Says Thank You to mb83 For This Useful Post: |
09-15-2014, 00:04 | #4 (permalink) | |
Member: 2256764 Status: Offline Thanks Meter: 0 | Quote:
09-15-2014, 00:35 | #5 (permalink) |
Member: 2256764 Status: Offline Thanks Meter: 0 | CURRENTLY i am not able to upload any attachment due to an error and cannot ad any URL :/ so i will do it in the morning and let u know...and one more question.. according to my knowledge he didnt remove that BLACKISH RESIN on the board after removing OLD U2 IC because i think he dont know about that..so is it necessary to remove it ? if yes than please let me know how to do it |
09-15-2014, 13:02 | #6 (permalink) | |
No Life Poster Join Date: Mar 2012 Location: cambridgeshire, England Age: 55
Member: 1728699 Status: Offline Thanks Meter: 212 | Quote:
All prints for this ic are needed, none are N/C. | |
The Following User Says Thank You to dog68 For This Useful Post: |
09-15-2014, 13:04 | #7 (permalink) | |
09-15-2014, 14:57 | #8 (permalink) |
Member: 2256764 Status: Offline Thanks Meter: 0 | oh i see..thanks for the reply but when he removed the old IC i saw that there were prints missing...so do u think that the BLACK resin also got off with it ? or the prints are OK?? and kindly tell me how to remove that epoxy |
09-16-2014, 12:16 | #9 (permalink) |
Member: 2205919 Status: Offline Thanks Meter: 33 | epoxy you should gently scratch in high temperature. I set about 300 degree… Glue is being very soft so i can remove it. It's very risky but if do it slowly and gently everything it'sshould be allright. Once i have a glue with some fibers in it. I've changed a lot of u2's but in this case when i removed glue a remove 5 pads… it was first case in my hole carrier |
09-16-2014, 16:02 | #10 (permalink) | |
01-20-2015, 22:33 | #14 (permalink) |
Junior Member Join Date: Nov 2014
Member: 2292360 Status: Offline Thanks Meter: 3 | same with me, i missing one pad on bottom right corner, then the phone not turn on, another case i broken another pad the the phone can turn on but can't charging, there is a way to fix this missing pad ? Thanks in adavance |
07-01-2015, 18:51 | #15 (permalink) | |||
Junior Member Join Date: Jun 2015
Member: 2409810 Status: Offline Thanks Meter: 0 | Quote:
missing U2 Pads A1, B1, E1, D6 and E6. Any Ideas to restore it? Quote:
Sorry, i cant link a picture because i'have got less then 10 Posts :-/ | |||
