09-26-2014, 19:07 | #1 (permalink) |
Major Poster Join Date: Mar 2011 Location: USA.
Member: 1536098 Status: Offline Thanks Meter: 4 | iPhone 5 U3 IC / R20 1) I received an iPhone 5 which lost these 3 chips Q3, U3, and DZ101_RF 2) I reballed all of the components succesfully. I used 500 degree celcius heat, and low air. However when I put the phone together the HOME BUTTON WAS NOT WORKING. But the power button was working fine. I also replaced R20 and R22 with resistors from an iPhone 4S I did not loose any pads. I have also put the board in a phone that is fully functional home button still does not work. QUESTIONS 1) CAN ANYONE TELL ME WHY THE HOME BUTTON IS NOT WORKING CAN ANYONE TELL ME WHY THE HOME BUTTON IS NOT WORKING 2) Also what Multimeter can I use to test tiny resistors like R20 ? |
09-26-2014, 19:29 | #3 (permalink) |
Member: 1536098 Status: Offline Thanks Meter: 4 | I doubt there are any problems with the U7 PMIC. Also the Power button is working. When I took out U3 the power button stopped working when I put it back in the power button started working again. Last edited by MrInformation; 09-26-2014 at 19:38. |
10-01-2014, 14:43 | #10 (permalink) |
Freak Poster Join Date: Jan 2013 Location: Switzerland Age: 48
Member: 1873863 Status: Offline Thanks Meter: 67 | R20 and R22 are critical and they are unique value on iphone5 (392Kohm). I have tried to replace those resistors with other similar values and i had problems too (first home button not working, then it was too much sensible). You should use same resistors from other iphone 5 board. |
