09-12-2014, 19:06 | #1 (permalink) |
Freak Poster Join Date: Jun 2014
Member: 2205919 Status: Offline Thanks Meter: 33 | Iphone 5 unknown device |
The Following User Says Thank You to mb83 For This Useful Post: |
09-12-2014, 20:18 | #2 (permalink) |
Junior Member Join Date: Aug 2012
Member: 1803458 Status: Offline Thanks Meter: 8 | U2 U2 responsible for usb and uart. In some cases , when it burn, voltage +5v can go to CPU usb data lines and cause breakdown of these lines. Also, u2 is very close to CPU and when you replace it there is a possibility of overheating and solderings balls under processor. CPU is very hard to reball, so do special analysis before reball. Try remove U2 and measure resistance between GND and contact pad that go to usb data lines. It should be equal and not in short circuit between d+ d- data lines. Also you can apply a 2v on laboratory power supply with stabilized amperage 100mA to contact pad of data lines. CPU should not consume a lot of current or be heated. |
The Following User Says Thank You to GPU5970 For This Useful Post: |
09-12-2014, 21:35 | #3 (permalink) |
Member: 2205919 Status: Offline Thanks Meter: 33 | Thanks for reply… This problem was before i've changed u2 so i think this is CPU problem… i'm shore that i do not overheat cpu. There is no other posibilites? some capacitor, jumper etc? If this really cpu this phone is trash |
09-13-2014, 00:26 | #4 (permalink) |
Member: 1803458 Status: Offline Thanks Meter: 8 | So that's another thing if it was the initial problem. 1 Check or replace dock 2 Check 5v on C304 capasitor with usb inserted if not ok- replace Q2 (usb 5v protector) and check or replace r111(5v fuse) 3 Check l20 l22 fl60 fl53 4 Check L1 L8(data lines inductors between U2 and CPU) If all ok, it can be CPU- how to check CPU in first post. |
The Following 2 Users Say Thank You to GPU5970 For This Useful Post: |
09-15-2014, 12:56 | #7 (permalink) |
No Life Poster Join Date: Mar 2012 Location: cambridgeshire, England Age: 55
Member: 1728699 Status: Offline Thanks Meter: 212 | With iphone 5, you have to be careful with tempreture, even when soldering on a coil, an underboard pre-heater is a good tool to have for these. |
09-16-2014, 15:05 | #8 (permalink) |
Member: 2205919 Status: Offline Thanks Meter: 33 | I replaced a lot of u2 and this is my first case with this kind of problem. Unfortunelly any solution in this topis was not worked. So i think this is cpu. Client wont be happy but what to do thanks for replies ! |
