Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 08-24-2014, 11:42   #1 (permalink)
Member: 1849962
Thanks Meter: 15
iphone 5 very hot wifi ic, drain battery fast
Hi
I have an iphone 5 that make a fake charging or a quick drain idont know/ if i try to charge it when it's full decharged it will do a bootloop.
After inspecting the mother board i find the antena switch totaly burned and the wifi ic very hot ,
After removing the antena switch and test , the wifi ic is steel very hot
So i have to replace the wifi ic or to jump U2 for charging problem
Thank you for any help
Old 08-24-2014, 12:17   #2 (permalink)
Member: 2205919
Thanks Meter: 33
Change U2… 100% work
Old 08-24-2014, 12:43   #3 (permalink)
Member: 1849962
Thanks Meter: 15
a defect U2 can make the wifi ic very hot?
Old 09-22-2014, 00:13   #4 (permalink)
Member: 1849962
Thanks Meter: 15
Finaly i removed the wifi ic and now the phone charge without problem . have to find an other wifi ic
Old 09-23-2014, 11:38   #5 (permalink)
Member: 1849962
Thanks Meter: 15
Hi again , after replacing the defective wifi ic by a new one , the wifi is still grayed , do i have to restore the phone? Because i dont want to go to ios 8
Old 09-23-2014, 12:40   #6 (permalink)
Member: 1873863
Thanks Meter: 67
Maybe you have heated too much the new module and killed..
how much temperature you used ?
Old 09-23-2014, 13:16   #7 (permalink)
Member: 1849962
Thanks Meter: 15
I used 220°C for the new one
Old 09-23-2014, 21:51   #8 (permalink)
Member: 1849962
Thanks Meter: 15
trayed to restore and now i have error 1669
Old 09-24-2014, 11:59   #9 (permalink)
Member: 1849962
Thanks Meter: 15
Hi again so error 1669 normaly is a u601 and u501 problem but this make no sense because before restoring i haved a baseband working and network working , and as i know you can restore any iphone with defective wifi , so any one can help me
Old 09-24-2014, 13:23   #10 (permalink)
Member: 1849962
Thanks Meter: 15
trayed with itune 11.0.5 and now getting error -1
Old 09-24-2014, 14:10   #11 (permalink)
Member: 1849962
Thanks Meter: 15
finaly there is a shortcut but i dont know were , so any one know wat is the capacitor that was directly linked to the baseband?
Old 09-24-2014, 14:56   #12 (permalink)
sidramobilecare's Avatar
Member: 888557
Sonork: 100.1608317
Thanks Meter: 34
baseband ic damaged
change baseband ic then update
Old 09-24-2014, 16:10   #13 (permalink)
Member: 1849962
Thanks Meter: 15
not easy , but i will try it
Page generated in 0.22142 seconds with 8 queries
