06-18-2015, 23:17 | #1 (permalink) |
Major Poster Join Date: Jun 2015 Location: Germany
Member: 2405157 Status: Offline Thanks Meter: 4 | Iphone 5 zebra lines now pin lost on PCB I was able to solve my screen issue with ghostibg and zebralines after replacing some caps. But only fir seconds because one soldered cap was loose and i lost a pin on the board. It is the cap left from c85 i think c396 maybe that should be in parallel to c85. Where can i solder the one now ,? On top of c85 or what would you suggest? With kind Regards Monty |
06-19-2015, 08:02 | #2 (permalink) |
Freak Poster Join Date: May 2015 Location: Ireland Age: 51
Member: 2393796 Status: Offline Thanks Meter: 10 | I had a look at schematics nothing left of C85 with a 300 number, C436 ? C396 is the other side of the board. is it the same size cap or a smaller one ? |
06-19-2015, 08:07 | #3 (permalink) |
Member: 2393796 Status: Offline Thanks Meter: 10 | C436 hot goes to hot end of C85 then C85 hot goes to 1 on FL33 Check to see continuity between see which one is ok then make trace and put cap between. |
