Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 04-21-2015, 14:00   #1 (permalink)
Member: 2382201
Thanks Meter: 4
iPhone 5C back camera freeze with front camera image
hi!
i have problem like on this video:
https://www.youtube.com/watch?v=-au9ZsfB5L
when i turn on camera app front camera work fine, but when i switch to back, then image from front camera is goin blurry and app frozen.
can you help me? ios 8.3.
Old 04-21-2015, 14:15   #2 (permalink)
Member: 929652
Thanks Meter: 20
you are change camera ok .
The Following User Says Thank You to hoangkien822003 For This Useful Post:
Old 04-21-2015, 14:59   #3 (permalink)
Member: 2382201
Thanks Meter: 4
im waiting for package with camera, but what else it can be? there is no black screen - there is a blurry image from front camera (picture not video like)
Old 04-21-2015, 15:22   #4 (permalink)
Member: 2320407
Thanks Meter: 88
You fix it by testing the voltages on main camera connector from working device ! then you will know where is the error
The Following User Says Thank You to ctccellulaire For This Useful Post:
Old 04-21-2015, 16:09   #5 (permalink)
Member: 2382201
Thanks Meter: 4
i dont have working 5C
The Following User Says Thank You to xbit11 For This Useful Post:
Old 04-21-2015, 16:57   #6 (permalink)
Member: 2320407
Thanks Meter: 88
Then search for schematics and search for the camera connector ways Pay ATTENTION for the black bold lines these are the main supply voltage check them one by one !
Old 04-24-2015, 18:13   #7 (permalink)
Member: 2382201
Thanks Meter: 4
flash also dont work, can camera change help?
ive made dfu restore but not success
Old 04-24-2015, 21:32   #8 (permalink)
Member: 2323433
Ok, friends also i have the same problem that values should get out if control with meter ??
The Following User Says Thank You to adry199769 For This Useful Post:
Old 04-25-2015, 07:56   #9 (permalink)
buds_guy's Avatar
Member: 2103580
Sonork: 100.1673399
Thanks Meter: 230
guys check and try this hope it will help gudluck
The Following User Says Thank You to buds_guy For This Useful Post:
Old 04-26-2015, 22:50   #10 (permalink)
Member: 2382201
Thanks Meter: 4
can you send me some video with technique about making so small jumpers?
if that coil is bad can i make jumper too?
Old 04-27-2015, 19:57   #11 (permalink)
Member: 2199965
Thanks Meter: 13
Just go and try Settings -> General -> Reset -> Erase All Content and Setting, then reactivate your iPhone
If fail, check camera connector first
The Following User Says Thank You to Ben15 For This Useful Post:
Old 04-27-2015, 22:07   #12 (permalink)
Member: 2095374
Thanks Meter: 24
Just replace cemara 100 % problem solve
The Following User Says Thank You to imranaslam khan For This Useful Post:
Old 04-28-2015, 21:07   #13 (permalink)
Member: 2382201
Thanks Meter: 4
ive replaced camera and working like a charm, but there also vibration dont work. I saw that connector on motherboard is a little bid broken (2-3 pins on bottom left), but other function of that flex works good (power button, volume buttons, mute switch, etc.).
How can i change that connector at home?
Old 04-28-2015, 23:34   #14 (permalink)
salahmohammad's Avatar
Member: 2386012
Thanks Meter: 94
you need to change the whole connector...de-solder and solder a new piece.
Old 04-29-2015, 05:57   #15 (permalink)
Member: 2382201
Thanks Meter: 4
i know but what devices and how can i do this? im not expert at microsoldiering
Page generated in 0.16261 seconds with 8 queries
