08-02-2014, 18:09 | #1 (permalink) |
No Life Poster Join Date: Apr 2008 Location: sweden
Member: 748544 Status: Offline Sonork: 100.1601881 Thanks Meter: 173 | iPhone 5c charging problem |
08-02-2014, 19:01 | #2 (permalink) | |
Super Moderator Join Date: Dec 1999 Location: In EveryOne's Heart
Member: 824 Status: Offline Thanks Meter: 25,151 | Quote:
1. Restart your iPhone 5 – Hard Restart You can try both restarts, the simple one and the hard one. Simple one is when you press the power button and it shows the power off slider, slide it to power off and then re press the power button to turn on the iPhone 5. Hard restart is when you press power and home button until it restart itself. Make sure that the charger is connected when you do the hard restart. 2. Turn off the iPhone 5 and then charge Turn off the iPhone 5 and then connect the charger, it usually works with partially faulty chargers whose current flow is intact but data isn’t probably. 3. Turn iTunes on / off and charge Test by once connecting the charger when itunes is on on your computer and then once when it’s off. It might work one way or the other and your iphone 5 might start charging. 4. Clean the line on iphone 5 charger slot and retry If resetting your iphone 5 didn’t get it charging again, better to check if the charger port of the charger itself is dusty and has lint. **** strongly to clean the iphone 5 charger slot, charger itself, usb slot and the usb slot. Once done, reconnect the charger to the iphone through computer. If that don’t work either, connect it with the wall charger. Try using any other computers usb port to see if your computer port is faulty and thus not charging your iphone 5. 5. Cross test with another iPhone 5 If you tried the above steps but they failed, try using the same charger with some other iPhone 5 to see if that the charger is fine or not. Once confirmed that the charger is fine, there might be the issue with your iPhone 5 charger slot or battery / circuit. 6. Change the iPhone 5 battery If the charger is fine but the problem is with your iPhone 5 battery, then better get a replacement battery and change your iPhone 5 battery. 7. Buy a new iPhone 5 Very much self explanatory! Hopefully this will get your iphone5 not charging issue solved! This might work with all previous versions of iPhones ------------------ Never lose Hope | |
