Iphone 5c no display I have one iphone 5c with no display, no backlight. It's not a water damage. Customer give to me with no display for change screen. I change but same problem (lcd is ok on another 5c), i test many screen. I restore many times but same. In recovery mode, i see the logo. When i restore, no display on iphone 5c, restore and activation is ok. I restore on two pc (only motherboard, battery, and connector) but same. I wait one week with motherboard only and restore done, same problem. I think it's hardware problem, have you got solution please or schematic. Thanks in advance. |
iphone 5c no soulition display |
I have the exact same problem although I have the schematics for the 5 5s and 5c ive tested the backlight filters all three show continuity..i tested the backlight diode also called the backlight ic ( wrong lable its a diode ) only thing I haven't tried is the coil which they don't usually go bad ...when they do the diode should be bad also...and or the filters...im stumped !!! |
i got iph 5c phone is on but lcd is white change screen allready ,flash phone but still same prob any solution ?? |
Does anyone have a solution for this? |
1 Attachment(s) |
1 Attachment(s) |
But to me it is enigma that the original lcd does not work (works on its original iphone) and a replacement lcd works flawlessly on the iphone which needs lcd to be replaced. And this happens on two devices. Where is the catch? |
1 Attachment(s) use tester ...from point to point , continuity = beep Attachment 345293 for other problem , for me Lcd to replace |
checked all of this but still the same |
iphone 5c no soulition displa |
iphone 5c backlight solution ? |
