08-31-2014, 12:37 | #1 (permalink) |
No Life Poster Join Date: Jun 2007 Location: France 72,77
Member: 521955 Status: Offline Thanks Meter: 261 | Iphone 5c no display I think it's hardware problem, have you got solution please or schematic. Thanks in advance. |
06-04-2015, 20:05 | #3 (permalink) |
Junior Member Join Date: Mar 2012
Member: 1729446 Status: Offline Sonork: mmaaxxs Thanks Meter: 0 | I have the exact same problem although I have the schematics for the 5 5s and 5c ive tested the backlight filters all three show continuity..i tested the backlight diode also called the backlight ic ( wrong lable its a diode ) only thing I haven't tried is the coil which they don't usually go bad ...when they do the diode should be bad also...and or the filters...im stumped !!! |
01-21-2016, 15:03 | #8 (permalink) | |
Freak Poster Join Date: Mar 2012
Member: 1740209 Status: Offline Thanks Meter: 36 | Quote: But to me it is enigma that the original lcd does not work (works on its original iphone) and a replacement lcd works flawlessly on the iphone which needs lcd to be replaced. And this happens on two devices. Where is the catch? | |
01-21-2016, 16:24 | #10 (permalink) |
No Life Poster Join Date: Oct 2012 Location: Republic of Serenissima
Member: 1825965 Status: Offline Thanks Meter: 874 | use tester ...from point to point , continuity = beep filters.JPG for other problem , for me Lcd to replace |
The Following User Says Thank You to orx For This Useful Post: |
