02-08-2016, 22:23 | #1 (permalink) |
Freak Poster Join Date: May 2013 Location: Netherlands
Member: 1939450 Status: Offline Thanks Meter: 165 | iPhone 5c no power I have an iphone 5c that wont power on after removing both touch ic? The iphone doesnt need these part to power up right? Or does it? Thanks in advance. |
02-08-2016, 23:16 | #2 (permalink) |
No Life Poster Join Date: Mar 2012 Location: cambridgeshire, England Age: 55
Member: 1728699 Status: Offline Thanks Meter: 212 | No it should power on, so what heat did you use? inspect the other ic's around, and other side of board. Test for short. Show me a picture of the board. |
02-09-2016, 06:42 | #3 (permalink) |
Member: 1939450 Status: Offline Thanks Meter: 165 | Thanks for your reply. I use 350 degrees celcius to remove the components. And protected the nand with shields + and iron coin on it. I don't see any heat spots in the board and there is no short to ground... I did accidently remove 2 caps (1 between the U12 and U15) and the other one next to the u15 ( side) I will add the names in a minute through schematics. But I don't think they should affect it. |
02-09-2016, 07:10 | #4 (permalink) |
Member: 1939450 Status: Offline Thanks Meter: 165 | Here are the names of the caps that are removed: C150 C165 C79 I will make a picture of the board tonight. PS. I just think that i made short to ground with R86. (but there is no ''beep' on + -) Last edited by timvandenboo; 02-09-2016 at 07:17. |
02-09-2016, 08:48 | #6 (permalink) | |
Member: 1939450 Status: Offline Thanks Meter: 165 | Quote:
But i dont think that is the problem. Because i didnt check the short before. (only after the phone wasnt booting anymore) I will check the short from R86 tonight. Hopefully that will fix the problem | |
02-09-2016, 16:36 | #8 (permalink) | |
Member: 1728699 Status: Offline Thanks Meter: 212 | Quote:
350 Is too much. 250 max i would say. depends on your station. | |
