07-02-2015, 09:55 | #1 (permalink) |
Freak Poster Join Date: Sep 2013
Member: 2029498 Status: Offline Thanks Meter: 11 | iphone 5c not charging problem when I plug in the cable to charge me that is connected in charge but the rate does not increase . I changed the battery and flex plug charging. solution? thanks |
07-04-2015, 19:59 | #3 (permalink) |
Freak Poster Join Date: Jan 2014 Location: Germany
Member: 2105007 Status: Offline Thanks Meter: 40 | have you beed using non original charging cable or car charging cable ? Chances are your u2 charging ic needs to be replaced. You can buy them on ebay for a few bugs and replace them if you have the skills: USB power ic for iphone 5s, 5c 1610A1 charging ic chip U2 36 pin 1610A1 | eBay |
The Following User Says Thank You to jackie8 For This Useful Post: |
07-06-2015, 22:29 | #4 (permalink) | |
Freak Poster Join Date: Nov 2014 Location: Germany
Member: 2289832 Status: Offline Thanks Meter: 48 | Quote:
07-07-2015, 05:32 | #5 (permalink) |
Member: 2105007 Status: Offline Thanks Meter: 40 | Stencil is always a problem, sometimes you get lucky and buy a good one but Most Stencil are bad. But in Germany the Deutsche Post are on a union strike so delivery time are really really bad in generell Smartphone-reha.com |
06-26-2016, 08:09 | #8 (permalink) |
Junior Member Join Date: Apr 2016
Member: 2566544 Status: Offline Thanks Meter: 0 | I have iPhone 5c with charging problem If it s turn on it charges normally percentage increase If it s turn off (both in the case of fully discharged battery that in the case of charged battery ) it doesn't charge ( usb detecter shows 0.00 ampere ) but clicking on power buttons it starts charging ( usb detector shows 0.90 ampere) and charging cycles goes good What do you think about ??? Changed battery but I didn't fix it Thanks Inviato dal mio iPhone utilizzando Tapatalk |
