Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 05-14-2015, 17:10   #1 (permalink)
Member: 1283129
Thanks Meter: 135
iPhone 5C only charge/connect in DFU mode
Hello friends,
I have an iPhone 5C.
When battery completely drained it will charge until the phone turns on and then stop charging (4%). Does not detect in iTunes.
Then you put in DFU mode and it connects fine. Leave it plugged in for an hour, then exit DFU mode and now phone fully charged.
No liquid damage. Board is perfectly clean with no broken components. I tried a different charge port flex, same result
Any idea what component bad. Maybe gas gauge?
Old 05-29-2015, 08:08   #2 (permalink)
Member: 2383469
How to put iPhone in DFU mode?
Hold the Power Button (3 secs)
Continue holding the power button and also hold the home button (15 secs)
Release the power button while continuing to hold the home button (10 secs)
Your device should prompt with the "Connect to iTunes Screen"
How to recover lost data from iPhone after putting it into DFU mode? Use FonePaw iPhone Data Recovery which is available for users to recover most of datas like contacts, photos etc.
Old 05-29-2015, 09:27   #3 (permalink)
Member: 2393796
Thanks Meter: 10
Change u2 ic maybe be the problem
try different cable / charger
Old 05-29-2015, 11:48   #4 (permalink)
Registered User
Member: 767472
Sonork: 100.1609877
Thanks Meter: 599
1st put in orignal cable
2nd Clean Board With Lequad like wash
3rd Chang U2 Ic This is Charging IC
Old 05-30-2015, 07:25   #5 (permalink)
Member: 1283129
Thanks Meter: 135
Solution was flux on connector and hot air 220C for 30 seconds. Wash with thinner. Working perfectly.
Page generated in 0.16861 seconds with 9 queries
