09-29-2015, 08:18 | #1 (permalink) |
No Life Poster Join Date: Mar 2015 Location: kapurthala punjab
Member: 2362867 Status: Offline Sonork: ththtuu Thanks Meter: 659 | iPhone 5s: Apple logo and then black screen - after screen replacement -If anyone has a link for a application like recboot that works, that would be appreciate as well, Thanks again! |
10-01-2015, 06:41 | #5 (permalink) |
Freak Poster Join Date: Nov 2014 Location: Germany
Member: 2289832 Status: Offline Thanks Meter: 48 | I have the same problm. Customer brought to me like this. First white apple logo black screen and then only black screen. I can see backlight is on from the orher side of screen. I changed u2, replaced batt Connector. The right screw hole is also a bit damaged i removed it the lines r a bit blank but not cut. I gonna change display pmu next and inform u. |
10-02-2015, 08:49 | #7 (permalink) |
Freak Poster Join Date: Mar 2014
Member: 2142442 Status: Offline Thanks Meter: 53 | i had the same problem and it was the PMIC New U7 338S1216 A2 IC for iPhone 5S Power Management IC 338S1216 | eBay check all capasitors from pmic |
10-03-2015, 04:37 | #10 (permalink) |
Member: 2362867 Status: Offline Sonork: ththtuu Thanks Meter: 659 | After change u2 your problam solve or not ? Sent from my GT-S7582 using Tapatalk |
The Following User Says Thank You to sachu2002 For This Useful Post: |
10-06-2015, 16:01 | #13 (permalink) |
Junior Member Join Date: Jun 2015 Location: Israel
Member: 2402174 Status: Offline Thanks Meter: 5 | i think its a flash ic problem i faced that problem one day try to write a new firmware from iTunes if its back to dfu again try to change flash ic carefully |
The Following User Says Thank You to ziaddd3x For This Useful Post: |
