02-14-2015, 12:49 | #1 (permalink) |
Freak Poster Join Date: Oct 2014
Member: 2277451 Status: Offline Thanks Meter: 18 | IPhone 5s battery discharge very very fast.. |
02-25-2015, 22:14 | #10 (permalink) |
Junior Member Join Date: Feb 2015
Member: 2348433 Status: Offline Thanks Meter: 3 | Yeap, if was droped in water try cleaning with tooth brush and alcohol, and put it on ultrasound cleaner about 20 mins at 50w, if problem persist, change battery connector on motherboard, i saw cases when short is under battery connector, if problem is still there after all this, you can also try to replace g2 ic, is usb driver, and can cause prolem like u2 ic. Last edited by phantom_IC; 02-25-2015 at 22:19. |
03-02-2015, 12:55 | #13 (permalink) |
Member: 2277451 Status: Offline Thanks Meter: 18 | I '' solved'' the problem. I have unsoldered Compass Control IC U16 AK8963C. It was already soldered in past, and it have two pins cut off. My question is: can iPhone work perfectly (with no iTunes error in restore) without this ic??? |
05-12-2015, 10:21 | #14 (permalink) | |
Freak Poster Join Date: Jun 2006
Member: 301521 Status: Offline Thanks Meter: 12 | 5s Quote:
hi same problem with my 5s too. 2 hour discharge. have you made any progress? what is current state of the device? thanks | |
