Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 03-20-2014, 16:49   #1 (permalink)
Member: 1804546
Thanks Meter: 2
iPhone 5S - blue screen after repair
Hi,
I have a problem after change control flex in iPhone 5S. I turn on and I see Apple logo, blue screen and device restart software. All elements on logic board is good (I think), one element is missing - screw spacer sleeve. I soldering area and soldering this element, but blue screen problem exist. If I try make restor, I have error 7/9 etc.
i.img ur.com/rTwZ1zm.jpg
Old 03-21-2014, 00:56   #2 (permalink)
Crazy Poster
Member: 2029794
Sonork: 100.1596147
Thanks Meter: 42
recheck any components, check connectors, or maybe some small parts was broken upon opening. try to change LCD 1st.
Old 03-21-2014, 11:27   #3 (permalink)
Member: 1804546
Thanks Meter: 2
I try other LCD yesterday and nothink new. I check components via microscope and I think everythink it's all right. Other idea?
Old 03-23-2014, 06:40   #4 (permalink)
Member: 1164898
Sonork: 100.1602306
check lighting coil near component
Old 03-24-2014, 10:45   #5 (permalink)
Member: 1804546
Thanks Meter: 2
Can you send me schematic for 5S or select on image because I dont have schematic for iPhone 5S.
Old 03-25-2014, 22:14   #6 (permalink)
Member: 2019991
master help needed for iphone 5 touch
i have an iphone 5 the problem with this phone is touch works automatic with out touching and some time didnt response
so any one can help to solve my problem i already clean all connectors still same problem
Old 03-25-2014, 23:27   #7 (permalink)
Member: 1759543
Sonork: no
Thanks Meter: 2
maybe you can change working t.s,sometimes tha panel of t.s is off value or something leaky..i incounter same your problem b4.i do this solution,it works
hope it help
Old 04-15-2014, 20:26   #8 (permalink)
Member: 229358
Thanks Meter: 12
please check the LCD connector cover position !!!!!!!!!
Old 04-30-2014, 11:13   #9 (permalink)
serkan45's Avatar
Member: 159363
Thanks Meter: 21
Does the scheme in hand
Old 04-30-2014, 12:03   #10 (permalink)
Member: 1405152
Sonork: adamsz123
Thanks Meter: 4
unplug the 3rd plug of screen (proximity sensor) or check the connector on pcb.
Old 04-30-2014, 22:17   #11 (permalink)
Member: 1766383
Thanks Meter: 4
Brother i think u brok the pcd line chack scro place near lcd and tach conctr
Old 04-30-2014, 23:13   #12 (permalink)
::. zine .::'s Avatar
Member: 161061
Thanks Meter: 568
problem in iphone 5s you must remove batterie before any operation i think that you have remove lcd and replaced it before remove batterie
Old 05-03-2014, 12:52   #13 (permalink)
Member: 2176390
Thanks Meter: 2
It is very simply to reboot blue screen iPhone:
Download iPhone data recovery program and install it on your computer. Find the Reboot Device app in installation directory and open it.
Connect iPhone with computer and once the program distinguishes your device, your iPhone will reboot to normal automatically.
Old 05-03-2014, 15:59   #14 (permalink)
Registered User
Member: 41430
pcb problem! errror code 14 yes?
Old 07-14-2014, 07:27   #15 (permalink)
brokendreem's Avatar
Member: 1150957
Thanks Meter: 60
i found 15 piece phone same problem
can any one share this problem solution..............
Page generated in 0.17049 seconds with 9 queries
