07-29-2014, 15:02 | #1 (permalink) |
Freak Poster Join Date: Dec 2013 Location: Veneto
Member: 2077335 Status: Offline Thanks Meter: 11 | iphone 5s blue screen help Have a problem with a 5s water damaged: i cleaned it with isopropyl and everything was working fine, except for the earpiece. I reopened it, reclosed it (to change earpiece), but now it boots up to the apple logo, then gives blue screen and turns off and on itunes gives error 9 what can i try to make it working again? thanks |
07-29-2014, 19:45 | #2 (permalink) |
Freak Poster Join Date: Aug 2013 Location: Germany
Member: 1996518 Status: Offline Thanks Meter: 15 | Are you sure you put the LCD connector shield screws in the right holes on main board? They have different lenght and you can damage NAND tracks Under threadhole if you screw in a screw which is to long. Use a microscope to look through screw hole on main boards surface. |
07-30-2014, 00:44 | #4 (permalink) | |
Member: 2077335 Status: Offline Thanks Meter: 11 | Quote:
unfortunately, i think that is possible...i will look with a microscope on it soon. In that case, there is something i can do? | |
07-30-2014, 00:51 | #6 (permalink) |
Member: 2077335 Status: Offline Thanks Meter: 11 | i'll add a picture: http://i60.tinypic.com/212hmx2.jpg (the two missing spacers was already broken when i bought it) Last edited by condenser; 07-30-2014 at 00:59. |
07-30-2014, 07:08 | #7 (permalink) |
Member: 1996518 Status: Offline Thanks Meter: 15 | Yes, especially the lower right one can make problems if you put in the wrong screw. But if they were missing before your problem, they aren't your problem I guess. Maybe the shield shorted some components because of the missing spacers? |
07-31-2014, 02:16 | #8 (permalink) | |
i have some professional equipments that have to be used | |
08-05-2014, 07:32 | #10 (permalink) |
Junior Member Join Date: Aug 2014
Member: 2234335 Status: Offline Thanks Meter: 1 | on my iPhone sometimes after a reboot the blue screen is displayed. I do reboot - everything is fine. after a few days the situation is repeated. it nervous me. What causes this? |
08-08-2014, 22:48 | #13 (permalink) |
Member: 2077335 Status: Offline Thanks Meter: 11 | i've tried putting the logic board on a perfectly working 5s same thing so, i think that i put a wrong screw... i'm gonna make that question: there is something i can do to fix that? there are a lot of same questions in this forum, and nobody that is able to answer to that |
08-08-2014, 23:30 | #14 (permalink) | |
No Life Poster Join Date: May 2010 Location: India,Tamilnadu-Nagercoil Age: 37
Member: 1314938 Status: Offline Sonork: 100.1672340 Thanks Meter: 5,373 | Quote:
The Following User Says Thank You to jamesjerss For This Useful Post: |
08-10-2014, 03:54 | #15 (permalink) | |
tried this...nothing. i noticed that one really small smd component near the right lcd connector is missing. i have another 5s that i can tear apart to fix that ordered an usb microscope, and i have good instruments... any suggestions? thanks!! | |
