07-25-2014, 07:13 | #46 (permalink) |
Freak Poster Join Date: Aug 2013 Location: Germany
Member: 1996518 Status: Offline Thanks Meter: 15 | Right screw hole see picture. |
The Following User Says Thank You to Exkurs For This Useful Post: |
07-25-2014, 11:40 | #47 (permalink) |
Freak Poster Join Date: Jul 2006 Location: TIMISOARA , ROMANIA Age: 34
Member: 310822 Status: Offline Sonork: ALIAS: POLITEHNICA_1921 Thanks Meter: 9 | changed u2 ic and still same problem ... could it be something else ? or should i try again with another u2 ic ? maybe it was bad soldering or something at the first try ... i'we got blue screen after changing boards between 2 phones... now i get error 14 restoring... |
The Following User Says Thank You to bumbalumba_1989 For This Useful Post: |
07-28-2014, 01:03 | #49 (permalink) |
Freak Poster Join Date: Jun 2012 Location: united kingdom
Member: 1777637 Status: Offline Sonork: 100.1616860:md Thanks Meter: 45 | Hi, I hv same problem and I change battery connector and it's was working fine. Please try it and post result. It was working for me so I hope will help for someone. Thanks |
08-02-2014, 22:26 | #51 (permalink) |
Junior Member Join Date: Jun 2008 Location: Turkey Age: 42
Member: 795785 Status: Offline Sonork: 100.1601618 Thanks Meter: 4 | Any one can help us about this problem i have 6 device on blue screen I trying to change: 1: ic power 2: earphone flex 3: battery 4: power flex 5: lcd 6: u2 ic 7: u22 ic |
08-04-2014, 09:05 | #52 (permalink) |
Junior Member Join Date: Nov 2007 Location: earth
Member: 634762 Status: Offline Thanks Meter: 1 | common problem is broken wires of the board if you swap bolts 2 are smaller then other two and when you screw one in wrong place circuit is cut for shure , check behind the hole with microscope if screw is touch board even small this is the problem |
The Following User Says Thank You to AC_SHNITZER For This Useful Post: |
08-05-2014, 17:45 | #54 (permalink) | |
Junior Member Join Date: Aug 2014
Member: 2235076 Status: Offline Thanks Meter: 1 | Quote:
08-09-2014, 10:41 | #56 (permalink) |
Junior Member Join Date: Feb 2011 Location: den haag
Member: 1514664 Status: Offline Sonork: [email protected] Thanks Meter: 0 | hhi sorry for mi english check display connector don't doe any thing only lose the skrow |
08-27-2014, 01:01 | #60 (permalink) | |
No Life Poster Join Date: Jun 2005 Location: Vietnam & China Age: 49
Member: 152057 Status: Offline Sonork: 100.1582385 Thanks Meter: 220 | Quote:
Thx for share ! | |
