Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 06-21-2018, 16:43   #1 (permalink)
Member: 2690483
iPhone 5s does not turn on error 40
Hi guys,
I am a bit stuck as I could not solve the issue. I have an iPhone which is totally dead but is recognized by PC. When I try to recover it through iTunes it gives error 40. When I connect to DCPS and press and hold power button it jumps to ~90mA and stays there.
No short on VCC_MAIN or battery. I also tested TriStar 1v8 and 3v0 lines and it shows 0v. My guess it is either PMIC or NAND.
Do you have aby suggestions?
Thanks in advance.
Old 06-21-2018, 18:01   #2 (permalink)
Member: 2219780
Sonork: 100.1662738
Thanks Meter: 52
Error 40 Nand not detected
Old 06-21-2018, 21:02   #3 (permalink)
Member: 2690483
I know that it is related with NAND but it could be either NAND itself or PMIC. I will try to test NAND power lines. If they are not present then it should be PMIC.
Old 06-22-2018, 06:41   #4 (permalink)
Member: 2816075
Thanks Meter: 8
Hello,
You should check the PP3V0_NAND line, if it is shorted one of the caps on this line is defective.
The Following User Says Thank You to elecsoluces For This Useful Post:
Old 06-26-2018, 17:44   #5 (permalink)
Member: 2690483
Just an update. I have checked PP1V2_NAND_VDDI, PP3V0_NAND, PP1V8 lines and all of them are present therefore I suspect NAND itself. What do you think?
Page generated in 0.13706 seconds with 9 queries
