03-29-2014, 11:41 | #1 (permalink) |
Freak Poster Join Date: Jun 2010
Member: 1325765 Status: Offline Thanks Meter: 3 | iPhone 5s fingerprint sensor not working anymore after replace now fingerprint not more working on iPhoen 5s In menue i dont have any settings. when i restore to factory defaults, they dont ask for finger print configuration? who can help? |
07-17-2014, 20:26 | #7 (permalink) |
Freak Poster Join Date: Oct 2013
Member: 2045117 Status: Offline Thanks Meter: 7 | I have here a 5S with a broken touch id/home button flex cable. If I want to use the TOUCH ID function again, can I swap this marked IC with the new flex cable? I think the data which is linked to the A7 is stored inside this small IC. |
07-29-2014, 20:12 | #10 (permalink) | |
Freak Poster Join Date: Mar 2014 Location: Nagoya
Member: 2140712 Status: Offline Thanks Meter: 40 | Quote:
same bro im try with original with swap still failed maybe this protec chip A7 from apple | |
09-04-2014, 19:09 | #11 (permalink) |
No Life Poster Join Date: Mar 2005 Location: Italy, Bahrain, India Age: 53
Member: 125037 Status: Offline Sonork: 100.1649338 Thanks Meter: 254 | Hi! What's the news on tis topic? So the solution is to swap the full motherboard? |
The Following User Says Thank You to excessive For This Useful Post: |
09-06-2014, 23:49 | #12 (permalink) |
Insane Poster Join Date: Apr 2006 Location: UK:London
Member: 268057 Status: Offline Thanks Meter: 16 | I had this problem and tried replacement buttons that did not work. I bought a complete faulty 5s mobile of the same colour (champagne) replaced the home button and I can confirm that the fingerprint sensor worked fine. So guys maybe there is some hope. What can we work out from this?? |
The Following User Says Thank You to mrblobby For This Useful Post: |
09-06-2014, 23:52 | #13 (permalink) |
Product Manager Join Date: Aug 2014 Location: London Age: 34
Member: 2247080 Status: Offline Thanks Meter: 52 | Check your sensor flex might connection bit loose, i also had problem like this , i repaired one iphone 5s after repair home button was working but sensor stop responding so i opened again and put the connection again and it starts working else put new button |
03-31-2015, 21:06 | #15 (permalink) |
Freak Poster Join Date: Sep 2008 Location: U.S.A
Member: 856640 Status: Offline Sonork: 100.1606320 Thanks Meter: 281 | this is only a warning... make sure that your device is off before connecting the ui flex of home button on iphone 5s,failure to do this the finger print sensor won,t work again. |
