03-20-2015, 20:56 | #1 (permalink) |
Freak Poster Join Date: Aug 2013 Location: Italy, Sardinia Age: 32
Member: 2014547 Status: Offline Sonork: 100.1665176 Thanks Meter: 18 | iPhone 5s Front Camera broken connector !!! |
03-21-2015, 11:57 | #3 (permalink) |
Member: 2014547 Status: Offline Sonork: 100.1665176 Thanks Meter: 18 | Is there any1 who can help me ? I got all the equipment to do it, kapton and hot air gun, but im not sure about temps, can you suggest me please ? |
04-03-2015, 20:47 | #4 (permalink) |
Freak Poster Join Date: Nov 2014 Location: Germany
Member: 2289832 Status: Offline Thanks Meter: 48 | buy a cheap flex and first try resolder connector there if you cannot, dont try. before unsolder clean area add flux add some fresh solder. I would use solder iron to remove. But you need be carefull |
06-30-2015, 07:51 | #7 (permalink) |
Freak Poster Join Date: May 2015 Location: Ireland Age: 51
Member: 2393796 Status: Offline Thanks Meter: 10 | just use a small iron to remove and replace use flux. make the pads flat no points with new solder use flux gel will help keep the connector in position. keep a tiny bit of pressure on the connector once in place with a small screwdriver or pin, solder a couple of legs at the ends to hold it there while you solder the rest. try and keep the connector flat as possible to the board. |
