02-06-2016, 18:36 | #1 (permalink) |
Junior Member Join Date: Feb 2016
Member: 2527768 Status: Offline Thanks Meter: 0 | IPhone 5s Lighting port replacement help So we both figured it was the port. Bought one off amazon and installed it. The installation process wasn't super easy but went very well. However, the battery seems not to accept a charge at all. When I plug in a lightning cable it just bootloops and if i plugged it turns off completely. It's like it doesn't even recognize that battery at all. Also I did not touch the battery. I only flipped off its connection while replacing the port. I did not even attempt to remove the battery. Any help is appreciated, thanks. Sent from my Nexus 6 using Tapatalk |
02-07-2016, 15:49 | #2 (permalink) |
Junior Member Join Date: May 2015
Member: 2397540 Status: Offline Thanks Meter: 3 | Hi, I think I am in the same boat, I have the same issue. what I noticed is that when I try to move slightly the connector on the motherboard I can have a voltage above 4V on the battery pins (1 and 4). When I put it just normally in place, I only have something like 1V. Did you check the voltage on the battery pins? |
02-11-2016, 00:02 | #3 (permalink) | |
Member: 2527768 Status: Offline Thanks Meter: 0 | Quote:
Where did you buy your replacement at? Was it a OEM or generic? Sent from my Nexus 6 using Tapatalk | |
