Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 01-09-2019, 07:29   #1 (permalink)
Member: 2479617
Iphone 5s no power
Hello,
I have an Iphone 5s board which was shorted. The shorted component on VCC_main is removed.
STAGE 1: After promt to boot the result was stable 0.05 A on DCPS and not recognized by the PC.
Power rails what i have measured:
PP_VCC_MAIN - 3,8 V
PP_BAT_VCC - 3,8 V
PP1v2_SDRAM - 0,01 V (Diode mode shows "353" = no short)
PP1V0_SOC - 1,0 V
PP_CPU - 1,0 V
PP_GPU - 0V (Diode mode shows "309")
PP_1v8 Always - 1,8V
PP1v2 - 0,01 V (Diode mode "383")
PP1v8_SDRAM - 0,07 V (Diode mode "624")
PP3v0_SDRAM - 0,20 V (Diode mode "629")
PP3v3_USB - 0V (Diode mode "520")
STAGE 2: PP1v8 RESET L was not present but not shorted also.
I did removed the display IC for the reset line - Phone started to boot nicely was like 0,1 - 0,5 Amps and then suddenly 0. And now it wont boot at all.
Suddenly the PP1v8 line is not present - Diode mode shows "1700" something.
These diode result's looks a bit not normal - right ? Should be like 300-400 ?
And also after the promt to boot all the power rail's are missing (but in diode mode does not show the short circuit - showing like "1230" and moving up.
Old 01-15-2019, 11:06   #2 (permalink)
Crazy Poster
Member: 7187
Thanks Meter: 12
some issues can be reduced to power management cpu failure - check for short the pw. supply circuits - in that case no solution cause most of them are glued
Old 01-16-2019, 12:47   #3 (permalink)
Member: 2479617
Hei,
Thanks for the replay. But can you be a more specific about the
"Power management CPU fail" - Here you are talking about the PMIC himself ?
As i have told , i have looked up the power rail's - Diode mode shows "1500" but that is not a "good" value.
Page generated in 0.21137 seconds with 7 queries
