Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 01-19-2015, 07:30   #1 (permalink)
fricosu007's Avatar
Member: 467437
Thanks Meter: 31
iPhone 5s Rear Camera stops responding
Hello guys, i have a 5s with strange problem, i don't know if it is because the latest update or replacing the housing, problem is that the rear camera is not working as it should, i replaced the camera, same issue, when you start it is either picture jammed, you can switch to front camera which works ok but when you switch picture of the front camera is also jammed but when closing and reopening the app the front camera works well, switching again from front to rear, picture freezes, a few attempts to check the board were done and nothing strange comes out, board is clean no water damage no anything, before when you were switching to front camera or even when you would start the app, the image was like flashing getting blurry and normal again and again until it would work even on the front / rear camera. now nothing at all, rear completely frozen, front works after restarting the app. flashing / cleaning / rebooting / hard resetting do not work. Please advice a hardware solution.
Old 01-19-2015, 07:37   #2 (permalink)
Member: 805211
Sonork: 1661191
Thanks Meter: 68
try to restore and post result.
Old 01-19-2015, 12:26   #3 (permalink)
Member: 40262
Thanks Meter: 11
check camera voltage and shorting caps near camera olso coil.
Old 01-19-2015, 21:10   #4 (permalink)
fricosu007's Avatar
Member: 467437
Thanks Meter: 31
restore does not help, already tried as 1st step.
Page generated in 0.66464 seconds with 8 queries
