12-21-2015, 19:51 | #1 (permalink) |
Freak Poster Join Date: Dec 2013
Member: 2080974 Status: Offline Thanks Meter: 12 | iPhone 5s stuck on apple logo after u2 replacement and q2 jumper Q2 jumpered like this: |
12-22-2015, 08:18 | #4 (permalink) |
Freak Poster Join Date: Mar 2014
Member: 2142442 Status: Offline Thanks Meter: 53 | http://www.*********.com/wp-content/...2Bsolution.jpg http://www.*********.com/2014/09/iph...-solution.html check your short first, and replace the U2 ic |
12-22-2015, 12:54 | #5 (permalink) |
Member: 2080974 Status: Offline Thanks Meter: 12 | First of all! The phone turned on, but the battery drained fast, and after a few days killed the battery, (an other shop changed battery), and didnt charge when the battery was empty... -I changed the u2 ic - still not charge -I removed the q2 and made the jumer - started charging, but the phone stuck on apple logo... -I remove the jumper and replace the u2 - still the same, stuck on apple logo! is it possible that because of the q2 jumper the pmic burnt? |
12-22-2015, 23:11 | #6 (permalink) |
Junior Member Join Date: Jul 2013
Member: 1979589 Status: Offline Thanks Meter: 0 | try restore cuz i have one that have blue screen and apple logo same as ur problem I changed u2 and still the same after that I restored it and work and that problem from cydia I think Sent from my iPhone using Tapatalk |
02-02-2016, 15:23 | #10 (permalink) |
Freak Poster Join Date: Oct 2012 Location: India
Member: 1821491 Status: Offline Sonork: Never give up Thanks Meter: 35 | Just change both U2 and Q2 clean properly 100% work and make sure U2 ic is original some time problem with bad ic done by me many times |
The Following User Says Thank You to rrvius For This Useful Post: |
11-28-2016, 20:41 | #15 (permalink) |
No Life Poster Join Date: Jan 2010 Location: South africa Age: 35
Member: 1197620 Status: Offline Sonork: 100.1602278 Thanks Meter: 647 | 100%tested if charging not show 100%tested if u r phone charging not show its not for charging saveing also if problem in usb u can bypass it |
The Following User Says Thank You to saleem5001 For This Useful Post: |
