08-17-2016, 17:11 | #1 (permalink) |
Freak Poster Join Date: Nov 2015
Member: 2484955 Status: Offline Thanks Meter: 14 | IPhone 5s Water Damage Iphone 5s water damaged I cleaned all the board than i checked components for corrosion than i changed corrosioned components. Now when i press power button device is stuck on 0.8 amp which ic i should check? Thanks |
08-17-2016, 17:49 | #2 (permalink) |
Junior Member Join Date: Aug 2016
Member: 2608253 Status: Offline Thanks Meter: 4 | Look for a short to ground on VCC_MAIN, usually the capacitor on the back of the board near the top left corner. |
The Following User Says Thank You to cbronson For This Useful Post: |
08-21-2016, 13:02 | #7 (permalink) |
No Life Poster Join Date: Jul 2016
Member: 2598526 Status: Offline Thanks Meter: 52 | L9 is an inductor it should measure 0 ohm if good. Don't mistake it for a short. Bad inductor coils measure open You need to find shorted capacitor or ic on vcc_main |
The Following User Says Thank You to short_toground For This Useful Post: |
