03-02-2015, 09:26 | #1 (permalink) |
Junior Member Join Date: Mar 2015
Member: 2354974 Status: Offline Thanks Meter: 3 | iphone 5s water damage, completely dead |
03-02-2015, 09:33 | #2 (permalink) | |
No Life Poster Join Date: Feb 2015 Location: PAKISTAN (OMAN) Age: 35
Member: 2340225 Status: Offline Sonork: 100.1662389 Thanks Meter: 367 | Do You Full Wash Quote:
The Following User Says Thank You to saifjaan009 For This Useful Post: |
03-02-2015, 11:25 | #5 (permalink) |
Junior Member Join Date: Feb 2015
Member: 2344322 Status: Offline Thanks Meter: 2 | Maybe a idea to check if the the battery connector has a short ? First meassure the battery not connected to the terminal, then test it connected to the terminal if there's no voltage reading then you have a short on the pcb. You can also do a "beep" test on the vcc and ground on the terminal connecto to see if it shorts. |
The Following User Says Thank You to NoToRiOuS26 For This Useful Post: |
03-03-2015, 17:55 | #7 (permalink) |
Major Poster Join Date: Jan 2010 Location: Europe
Member: 1208225 Status: Offline Thanks Meter: 13 | There are several small components in size 0201 which you might not see if they are cracked. It could be your problem, several cracked components due to shorting cause of the water. |
The Following User Says Thank You to gkhn For This Useful Post: |
