Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 07-23-2015, 09:28   #1 (permalink)
Member: 2431552
iPhone 6 | this accessory is not supported!
hi all!
i have iphone 6 not charging. i change battery and charging cable
still not charging. please help me! thanks
Old 07-23-2015, 12:47   #2 (permalink)
Member: 2105007
Thanks Meter: 40
using a non oem charging equipment, might have damaged the u2 ic on the iphone 6. This was a big issue in Iphone 5 series and since the iphone 6 is using almost the same u2 ic (16103) chip , it is possible we got the same issue.
u2 needs to be replaced, if my assumtion is correct.
Old 08-01-2015, 02:10   #3 (permalink)
Member: 2398349
Thanks Meter: 62
Originally Posted by kunkezly View Post
hi all!
by charging cable u mean charging port??
if not u have to change that too before u do any hardware!!
Old 08-01-2015, 08:52   #4 (permalink)
Member: 2437344
The source maybe your Charging cable or Charging cube. Pleae double check to make sure that they are original Apple products. Many charging USB cable and cube out there are low quality products and will damage your phone. USE original charger only.
Old 08-18-2015, 06:27   #5 (permalink)
Member: 241855
Sonork: 1623913
Thanks Meter: 89
hi all!
buy oem charger and your problem solved
Old 10-01-2015, 16:44   #6 (permalink)
irzhan01's Avatar
Member: 2281582
Thanks Meter: 26
change ic u2.. solved ..
Old 10-02-2015, 06:09   #7 (permalink)
Member: 1283129
Thanks Meter: 135
95% just aftermarket charger. Try with 100% original charger. Don't listen to stupid people, aftermarket charger won't damage anything. 5V is 5V. I'm no expert but I'm selling/repairing phones for 15 years and have never seen a phone damaged by aftermarket charger.
Old 10-02-2015, 09:33   #8 (permalink)
irzhan01's Avatar
Member: 2281582
Thanks Meter: 26
Yaa.. Thats right.. But this case is board problem.. So if u not change u2 ic it wont charging even u buy original Charger.. :-).. So change u2 first then use original charger..
Sent from my iPhone using Tapatalk
Old 10-03-2015, 07:53   #9 (permalink)
Member: 126801
Thanks Meter: 23
change the U2 IC.......
Old 11-19-2015, 12:19   #10 (permalink)
irzhan01's Avatar
Member: 2281582
Thanks Meter: 26
Anyone have solution of battre precentage not work .. For iPhone 6..change U2 still same .. Thanks
The Following User Says Thank You to irzhan01 For This Useful Post:
Old 11-30-2015, 20:27   #11 (permalink)
Shahin Hasan's Avatar
Member: 1529244
Sonork: 1720
Thanks Meter: 150
hi all!
Replace u2 ic it will be done.
Old 12-01-2015, 01:54   #12 (permalink)
Member: 2491638
Use MFI cable, or replace U2 ic
Old 12-01-2015, 08:13   #13 (permalink)
Member: 2386502
Thanks Meter: 6
I got cheap rate toughened glass for iphone 6 form Moskart
Old 12-01-2015, 15:58   #14 (permalink)
Member: 2494621
Thanks Meter: 2
i already replace iphone 6 u2 ic but changing not save please halp me?
Old 12-01-2015, 17:34   #15 (permalink)
irzhan01's Avatar
Member: 2281582
Thanks Meter: 26
Same with me .. Battre precentage not work .. Device sometime reboot ..anyone know battre way iPhone 6.. ?
Page generated in 0.22561 seconds with 8 queries
