01-21-2017, 23:27 | #1 (permalink) |
Crazy Poster Join Date: Jan 2017
Member: 2670415 Status: Offline Thanks Meter: 8 | IPHONE 6 backlight ? (iphone needs to cool down before you can use it ) then i restart the phone and apple logo shows then black , just (backlight) |
The Following User Says Thank You to LIKE_ For This Useful Post: |
01-23-2017, 09:05 | #6 (permalink) |
Member: 2670415 Status: Offline Thanks Meter: 8 | this some photos http://www.file-upload.cc/5gzt04abxc15 http://www.file-upload.cc/o8lywawrqy0o PS: The phone is detected by itunes in recovery mood i tried to get out of recovery mood with reiboot app i couldn't |
01-23-2017, 09:39 | #7 (permalink) |
Member: 2670415 Status: Offline Thanks Meter: 8 | is this a jumper for FL2024 ? http://www.file-upload.cc/wzb9exm2gxq0 and do you think the problem because of it ? i checked FL2024 in a beep mode with TP2520 it's beeping and with C2017 and it's beeping two |
01-23-2017, 10:22 | #8 (permalink) | |
Freak Poster Join Date: Jul 2008 Location: Earth
Member: 813803 Status: Offline Thanks Meter: 120 | Quote:
The Following User Says Thank You to zarbourne For This Useful Post: |
01-25-2017, 03:08 | #13 (permalink) |
Member: 2670415 Status: Offline Thanks Meter: 8 | so , here is a video on backlight line is this line ok or manipulated with ? i'v put the negative in C1530 and the positive with (FL2024<< I don't have the filter there is a jumper) and TP2520 and J2019 Backlight pin )) it's all beeping that's mean they'r connected together is it ok that they'r connected ? https://www.youtube.com/watch?v=A7RtsLIvdKU |
01-25-2017, 12:32 | #14 (permalink) | |||
01-25-2017, 12:47 | #15 (permalink) |
Member: 813803 Status: Offline Thanks Meter: 120 | - First I recommend to replace jumpers for FL2024 & FL2025 & FL2026 with real ferrite from other phone or new one. - Check voltage of VCC_MAIN = 4V, if voltage low or no voltage, let me know. - Check voltage of PP1V8 voltage = 1.8V & PP1V8_SDRAM voltage = 1.8V, if voltage low or no voltage, reball pmic - If C2017, C2018, C2019 look like they have corrosion, repalce them - Replace L1503 Coil - Replace D1501 Diode - Reball U1502 IC, better to replace if you can - Reball PMIC Don't do all at once, test after each step. If this not fix your problem, then issue is 90% not backlight circuit. Let us know how it goes bro, Good luck. |
