02-28-2018, 10:10 | #1 (permalink) |
Junior Member Join Date: May 2017
Member: 2716020 Status: Offline Thanks Meter: 0 | iPhone 6 backlight chip U1502 with missing pin i have a iPhone 6 with a backlight problem. I changed the backlight chip u1502 but when i removed it i lost 1 pin. C2 is the missing pin. is there a solution to jump or wire this pin on the motherboard? i soldered the u1502 chip with the missing pin but didn't work. thanks in advance |
02-28-2018, 14:14 | #4 (permalink) |
Freak Poster Join Date: Nov 2017 Location: Canada
Member: 2777379 Status: Offline Thanks Meter: 34 | Well before dumping it you could try removing the CPU and making a jumper, it is possible just very hard, you would need to cure a 0.05mm jumper wire underneath the CPU with solder mask so it doesnt short with other pads, I've done similar repair before and was successful, what have you got to lose? |
The Following User Says Thank You to 7Axis For This Useful Post: |
02-28-2018, 14:44 | #5 (permalink) |
Freak Poster Join Date: Dec 2015 Location: Canada
Member: 2498972 Status: Offline Thanks Meter: 33 | There is one possibility that hasn't been mentionned... There is an external point of access, it's called PP1301. However, it is directly in between the PMIC (U1202) and CUMULUS (U2401). You would have to remove them both, make the jumper and put those IC's back in place. Still. this would be much easier than removing/reballing the CPU. Working on the CPU is a low probability repair unless you have done it many, many times successfully before. |
The Following User Says Thank You to minho For This Useful Post: |
02-28-2018, 14:47 | #6 (permalink) |
Member: 2716020 Status: Offline Thanks Meter: 0 | i understand that it is possible with jumper on the cpu pads but its not time/worth it. If i have enough time to do this repair i will think about it. I was thinking of a "simple" fix and not this much time taker fix. Thank you for your idea. I appreciate it. |
03-01-2018, 01:36 | #9 (permalink) |
Member: 2498972 Status: Offline Thanks Meter: 33 | Exactly, you will have to run the jumper from PP1301 to the missing pad, secure it in place with UV-Curable mask so that when you reball the IC and solder it into place, it will properly connect to the jumper. |
