03-16-2017, 16:58 | #1 (permalink) |
Freak Poster Join Date: Jan 2016 Location: Hungary
Member: 2515187 Status: Offline Thanks Meter: 114 | iphone 6 backlight issue iphone 6 no backlight. I replaced: U1502 (3 times) D1501 L1503 U1501 Filters OK. but still problem. BL_ANODE: 4.2V (without LCD) and 20V (with LCD) BL_CAT1: 0.3V (without LCD) and 0.0V (with LCD) BL_CAT2: 0.3V (without LCD) and 0.0V (with LCD) Thanks for your reply. |
03-16-2017, 19:46 | #2 (permalink) |
No Life Poster Join Date: Mar 2012 Location: Amsterdam, Netherlands
Member: 1732818 Status: Offline Thanks Meter: 532 | I had the same problem, in my case it was C1505 shorted to ground. After removing, The backlight came alive. you might also check C1531 and C1530 if shorted to ground. |
The Following User Says Thank You to HDccam For This Useful Post: |
04-06-2017, 08:11 | #6 (permalink) |
No Life Poster Join Date: Sep 2005 Location: London, UK
Member: 178513 Status: Offline Thanks Meter: 109 | The same, i got during the week 2 cases not resolved changing Caps, coil, diode, IC after no short at all, filters and tracks OK, i have repaired 4 pcs all successful... Sent from my iPhone using Tapatalk Pro |
04-06-2017, 12:01 | #7 (permalink) | |
Freak Poster Join Date: Feb 2007 Location: i amm livinig in tukrey
Member: 454060 Status: Offline Thanks Meter: 12 | Quote:
and PP_VCC_MAIN under u1501 | |
04-28-2017, 16:09 | #8 (permalink) |
Freak Poster Join Date: Jan 2004 Location: FRANCE Age: 36
Member: 49046 Status: Offline Thanks Meter: 25 | hi Can you show me how do you check them please ? i have already change coil, diode, filters ic and check all tracks but without success. when i solder U1502 i have these caps which are shorted C1597 C1552 but when i desolder it they are not shorted. i think i have a problem with PP1V8_SDRAM |
