Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 01-20-2017, 11:37   #1 (permalink)
Member: 2611799
Iphone 6 no display diode d1501 burning
Hello I received iphone 6 which boot perfectly but that displays nothing I noticed that the diode d1501 was burning I desolder the diode and test the resistance of the line pp_lcm_bl_anode and my multimeter displays 200 ohm while on 1 iphone that works I have no value Do you think the capacitor c1505 c1531 c1530 could be in question? Can 1 capacitor be half short and cause this low 200 ohm value? Or is it the chip u1502? What do you think ? thank you
Old 01-20-2017, 13:08   #2 (permalink)
Member: 813803
Thanks Meter: 120
D1501 heating up indicates your backlight system is down..
1.Check voltage make sure:
- VCC_MAIN = 4v
- PP1V8_SDRAM= 1.8V
- PP1V8 = 1.8V
- TEST
2.Check if any of these are shorted or damaged:
- C1513
- C1552
- C1597
- C1530
- C1531
- C1505
- C2017
- C2018
- C2019
- TEST
3.Change following:
- U1502
- L1503
- D1501
Let me know how it goes!
Old 01-20-2017, 17:49   #3 (permalink)
Member: 2611799
I wanted to know if 190 ohm can be considered short circuit?
Can a capacitor not be completely short and create a small resistance of 190 ohm?
VCC_MAIN = 3.75 - 3.90 Its rise and fall
- PP1V8_SDRAM= 1.8V
- PP1V8 = 1.8V
C1513 = 190 ohm
- C1552 = 190 ohm
- C1597 = 1400 ohm
- C1530 = 1400 ohm
- C1531 = 190 ohm
- C1505 = 190 ohm
- C2017 = 190 ohm
- C2018 = no short
- C2019 = no short
Old 01-20-2017, 20:19   #4 (permalink)
Member: 2598526
Thanks Meter: 52
- PP1V8_SDRAM= 1.8V
- PP1V8 = 1.8V
C1513 = 190 ohm
- C1552 = 190 ohm
- C1597 = 1400 ohm
- C1530 = 1400 ohm
- C1531 = 190 ohm
- C1505 = 190 ohm
- C2017 = 190 ohm
- C2018 = no short
- C2019 = no short
Do a diode mode check with the diode removed. Positive pin on ground, negative pin on each side where diode goes.
If you get a low reading <.3v drop then there's a short in the direction of the pin that measured low.
If it's after the diode check the caps. One could be leaky causing a partial short. If it's before filtering caps check the ic or supply to ic
Old 01-21-2017, 12:03   #5 (permalink)
Member: 2136572
Sonork: 100.1653162
Thanks Meter: 41
- PP1V8_SDRAM= 1.8V
- PP1V8 = 1.8V
C1513 = 190 ohm
- C1552 = 190 ohm
- C1597 = 1400 ohm
- C1530 = 1400 ohm
- C1531 = 190 ohm
- C1505 = 190 ohm
- C2017 = 190 ohm
- C2018 = no short
- C2019 = no short
Hello Dear.
Having a 190 Ohms on the capacitors ( C1530, C1531, C1505) means that at least one of these capacitors is damaged, could be that is not totally shorted but it's damaged and will create an over consuming of the current which will burn the diode (D1501).
Please remove the capacitors one by one and test.
Thanks for Solution source
( www.tsa-mtech.co.uk ) SFS software.
Sent from my iPhone using Tapatalk
The Following User Says Thank You to AYSER For This Useful Post:
Old 01-21-2017, 16:44   #6 (permalink)
Member: 2611799
I plugged a power supply with 2 volt + on most of the line pp_lcm_bl_anode and the - to ground and I put the freez bomb and the capacitor c1505 melted very quickly.
Now I will replace it and re-solder the diode and I would tell you if it works
Old 08-13-2017, 23:34   #7 (permalink)
HDccam's Avatar
Member: 1732818
Thanks Meter: 532
I had the same problem.. and fixed it.
Your problem is almost for sure C1530 short to ground.
And yes 600 Ohm shortcut means, your diode will burn too!*
So just remove c1530 and your diode will not burn anymore
Page generated in 0.14357 seconds with 8 queries
