06-15-2017, 18:25 | #1 (permalink) |
Freak Poster Join Date: Oct 2010
Member: 1422282 Status: Offline Thanks Meter: 23 | Iphone 6 backlight trolling me Sent from my iPhone using Tapatalk |
06-18-2017, 14:40 | #2 (permalink) |
Freak Poster Join Date: Jun 2014
Member: 2205919 Status: Offline Thanks Meter: 33 | Check all capacitors on this line... not remove, replaced it. I had similar problem. When you remove capacitor your backlight diode or ic will burn. I think now you have to replace backlight ic. But remember to check all capaciotors and replaced if short. I hope this helps. |
The Following User Says Thank You to mb83 For This Useful Post: |
06-18-2017, 20:14 | #4 (permalink) |
Member: 1422282 Status: Offline Thanks Meter: 23 | Burnt diode is caused by anode line , most likely anode line gets short cos of three caps on the line. Check those caps and replace the faulty one n then replace diode , you ill get your backlight. Mine case was different, i had internal short in lcm cat 1 so i jumped that line .. Sent from my iPhone using Tapatalk |
06-18-2017, 20:21 | #8 (permalink) |
Member: 1422282 Status: Offline Thanks Meter: 23 | Yeh, but that is highly unlikely, cos diode always gets burn cos of short as I explained before.. Good luck Sent from my iPhone using Tapatalk |
The Following User Says Thank You to shani1122 For This Useful Post: |
06-19-2017, 20:19 | #14 (permalink) |
Member: 1422282 Status: Offline Thanks Meter: 23 | That ill work 4 sure. I know its bit tough when you are new in micro soldering but thats how you learn. Try to wiggle out the actual problem. I got one phone same like yours today,i already replaced faulty cap and diode but still no backlight. i m also going to replace backlight ic tomorrow or after tomorrow. I Sent from my iPhone using Tapatalk |
