07-19-2015, 18:33 | #1 (permalink) |
Junior Member Join Date: Jan 2014
Member: 2098728 Status: Offline Thanks Meter: 0 | Iphone 6 battery drain I have problems with my iphone 6 he is discharging battery very fast, i can do on standby just 6 - 8 hours. It has no water damage, I tryed to change the battery, but same problem. Any ideas? greetings, Ronald |
07-21-2015, 10:23 | #3 (permalink) |
Junior Member Join Date: Jun 2015
Member: 2414159 Status: Offline Thanks Meter: 3 | Try below methods: 1. Check if the connection between the USB port and the charger is loose. 2. Check if your charger is in good shape and always use original charger. 3. Double check the USB charger port on your device. 4. Check the battery to see if it’s aging or bulging. 5. Check if the battery contacts are in good condition. 6. Check the resistance with a multimeter to confirm everything is working normally. 7. Check if the U2 IC chip is inveraciously soldered or damaged. |
The Following 3 Users Say Thank You to m$m For This Useful Post: |
07-28-2015, 07:50 | #6 (permalink) |
Major Poster Join Date: Mar 2015
Member: 2356101 Status: Offline Thanks Meter: 1 | imore has published a post with the title "How to fix iPhone battery life problems!". You can follow the tips on this post to fix your problem. If it is of no use you can get a new iPhone 6 battery replacement from www dot hcqs dot com dot cn and replaced the old one. |
The Following User Says Thank You to Karelxy For This Useful Post: |
08-16-2016, 19:06 | #7 (permalink) |
Freak Poster Join Date: Oct 2012 Location: India
Member: 1821491 Status: Offline Sonork: Never give up Thanks Meter: 35 | Sasan500 Replaced 2 U2 ic's but not slove same I have done some of iPhone 6 before same problem battery drain very fast now but in this case replaced U2 problem is same what do I do next please fix this |
08-23-2016, 17:50 | #11 (permalink) | |
Member: 1821491 Status: Offline Sonork: Never give up Thanks Meter: 35 | Quote:
Problem solved in iPhone 6 and 6 plus some time changing U2 only ll not work for fake charging or heat battery drain very fast or once battery goes 0% and doesn't charge it's means some other ic also damaged replace 1401 and 1403 one by one and Chq 1000% work Sent from my iPhone using Tapatalk | |
09-03-2019, 15:12 | #12 (permalink) |
Freak Poster Join Date: May 2016 Location: Unlock world Age: 35
Member: 2578723 Status: Offline Thanks Meter: 15 | Often times battery draining problem means U2 IC chip is failed to work properly. You may want to use thermal camera or freezer to test it. Go ahead and spray freezer, let it cool down and connect AC voltage 4.2V on and you will see U2 highlights itself. And AC meter show about 0.22W. Also, while testing with camera U2 gets warmer and it highlights itself as it turns red in camera display. I hope it will help! |
