Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 03-12-2019, 14:46   #1 (permalink)
Member: 2127758
Thanks Meter: 20
iPhone 6 battery drain - No U2
I've got an iPhone 6 with battery drain but the problem is not U2 (changed twice)...
All work fine but there is a huge battery drain...
Any solution?
Old 03-12-2019, 15:46   #2 (permalink)
ninos22's Avatar
Member: 1903358
Thanks Meter: 136
Freeze board and find the warm spot.
Old 03-12-2019, 17:49   #3 (permalink)
Member: 2127758
Thanks Meter: 20
I've already tried but the phone warmp up just a little so i'm unable to identify the hot zone...
Old 03-12-2019, 20:40   #4 (permalink)
kimo59's Avatar
Member: 183437
Thanks Meter: 97
it could be home button, short capa in wifi ic itself or ant partial short on motherboard after U2 rail, try with alcohol iso to clean board with help of microscope.
Best Regards.
The Following User Says Thank You to kimo59 For This Useful Post:
Old 03-13-2019, 17:07   #5 (permalink)
Member: 2127758
Thanks Meter: 20
Best Regards.
I've think C5202_RF me too, so i've remove it...
but still the same...
even without home button and camera...
We use only no-clean flyux, by the way i've already clean the entire mainboard with isop. without success...
Battery still drain fast...
Old 03-13-2019, 20:17   #6 (permalink)
CDMA_RASHID's Avatar
Member: 821646
Thanks Meter: 437
Use DCPS and check for power consumption.
Normal consumption of a perfect phone would be 40mAH on initial power press and will gradually increase.
If the power consumption is 100 mAH that means any of the 3v0 power supply is short to ground.
You need to check all power rails that has 3 volts on it.
For example check
pp3v0_TRISTAR
PP3V0_PROX
PP3V0_MESA
PP3V0_IMU
I have excluded Nand voltage because if this rail gets short the phone will not power on at all.
Check for short on the above power rails. If short found on any one of them check corresponding caps connected on that line.
Use Schematic and PhoneBoard for tracing and fault finding.
Hope that helps.
The Following 3 Users Say Thank You to CDMA_RASHID For This Useful Post:
Old 03-14-2019, 11:48   #7 (permalink)
Member: 2127758
Thanks Meter: 20
For example check
Hope that helps.
Thanks bro,
pp3v0_TRISTAR ... OK
PP3V0_PROX .... Absent but no short on C2108
PP3V0_MESA ... OK
PP3V0_IMU ... Absent and short on C1284
I've removed C1284, C2272, C2271, U2205 but still shorted...
I've to replace U1202?
Old 03-14-2019, 12:14   #8 (permalink)
Member: 821646
Thanks Meter: 437
Remove C1902.
Hope that helps.
Old 03-14-2019, 14:02   #9 (permalink)
Member: 216844
Thanks Meter: 26
Home button .............................................
Old 03-14-2019, 22:54   #10 (permalink)
tochits's Avatar
Member: 856640
Sonork: 100.1606320
Thanks Meter: 269
Any solution?
did you tried to change battery?
Old 03-14-2019, 23:12   #11 (permalink)
Member: 2899986
Sonork: bagani
try to change this ic U1401
Hope that helps.
Old 03-15-2019, 12:08   #12 (permalink)
Member: 2127758
Thanks Meter: 20
Remove C1902.
Hope that helps.
Solved, thanks bro...
I've forgot C1902!
U got PM
The Following 2 Users Say Thank You to Sakalalina For This Useful Post:
Old 03-27-2019, 08:59   #13 (permalink)
Member: 134922
Thanks Meter: 3
where is the place c1902?
Old 03-27-2019, 09:20   #14 (permalink)
ali_imran's Avatar
Member: 481609
Sonork: 100.1659889
Thanks Meter: 360
if u search in any tool u can find it
here is c1902
Page generated in 0.46186 seconds with 8 queries
