Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 07-03-2018, 14:07   #1 (permalink)
Member: 2748562
Thanks Meter: 11
iphone 6 doesn't charge again
I've replaced charge port flex cable, and the iphone works fine for 2 weeks. Now again it doesn't charge anymore.I checked this with a few chargers and cables. What can it be?
Thx
The Following User Says Thank You to service32 For This Useful Post:
Old 07-03-2018, 14:16   #2 (permalink)
bobo bokota's Avatar
Member: 2148606
Sonork: Bobobokota
Thanks Meter: 496
Thx
try to test u2 before changing flex port cable
Envoyé de mon SM-G532F en utilisant Tapatalk
The Following User Says Thank You to bobo bokota For This Useful Post:
Old 07-03-2018, 15:23   #3 (permalink)
Member: 2748562
Thanks Meter: 11
I'm afraid I don't understand you. Please can you be more explicit? u2?
Old 07-04-2018, 10:15   #4 (permalink)
Member: 2833946
Thanks Meter: 108
Maybe is the hardware Issue - Logic board damaged. You can analysis why your iPhone 6 won't charge as follows. Also you can go here to watch the video, including charing fault analysis and detail repair steps
Charging fault analysis
Connect ZXW to a computer, open PCB diagram software, Charging voltage input PP5V0_USB, battery voltage PP_BATT_VCC, Battery electric quantity detection BATTERY_SWI_CONN
Connect U1401, Tigris charger, USB control IC, overvoltage protection signal, U1700 damage can result in not charging, reboot and connect computer failure etc.
Charging fault detection
Open iPhone 6 screen, take down the screen, pull up the battery connector from logic board. The voltage is about 2.0V after measurement through stitch battery is ok.
Plug to charger, the voltage is 0.5V(normal 1.8V – 4.2V) after measurement through FPC connector, the logic board can’t charge.
The Following 2 Users Say Thank You to AmieeWhite For This Useful Post:
Old 07-05-2018, 12:50   #5 (permalink)
Member: 2148606
Sonork: Bobobokota
Thanks Meter: 496
I say you have tested U2 (U1700)
Page generated in 0.20631 seconds with 9 queries
