05-01-2017, 10:42 | #1 (permalink) |
No Life Poster Join Date: Jun 2006 Location: Philippines
Member: 302596 Status: Offline Thanks Meter: 784 | iphone 6 error 9 and error 14 DONE unit : iPhone 6 Problem: Restart after open menu history : suddenly off and then goes to restart continuously diagnose : the board is clean and not shorted so i decided to restore but its come up with error 9 so i decided to dig out the nand and reball and update/restore but still it comes up with error 9 i decided to change new nand ic and after restore it will become error 14 even i change to many nand program nand but still it gives me the same error ( error 14) and stock on 34% then error 14 Solution?change U0301 ONSEMI EEPROM i did not attach the picture how to rebal the nand and back to the board i know you know how to work with it and the finally Question ? how do i know that the ONSEMI EEPROM damage ? when i check on power supply it seems all are okay and the other component and when i remove the ONSEMI EEPROM its seems the reading going CPU is normal thats all dont shame to hit the thanks button you earn money for this guide, 1 thanks button is enough |
The Following 72 Users Say Thank You to maxieboy For This Useful Post: |
05-07-2017, 14:28 | #5 (permalink) |
No Life Poster Join Date: Jul 2008 Location: Mumbai Age: 36
Member: 821646 Status: Offline Thanks Meter: 507 | Ipbox is quick and very cheap compared to wltools lengthy procedures. Ipbox does similar jobs pretty easily with less effort and less money. |
The Following 2 Users Say Thank You to CDMA_RASHID For This Useful Post: |
05-08-2017, 03:48 | #6 (permalink) |
Registered User Join Date: Dec 2012 Location: canada
Member: 1848477 Status: Offline Thanks Meter: 3 | Great post !! Question : You replaced the eeprom from one from a donor board right ? Question 2: How did you know the eeprom was the problem ? You say everything looked ok, then how did you manage to know it was the eeprom ? |
The Following User Says Thank You to cheebster For This Useful Post: |
06-14-2017, 03:51 | #7 (permalink) |
Member: 302596 Status: Offline Thanks Meter: 784 | as i posted above i check everything, so i doubt that the eeprom was damage and viola im correct and the result is ? |
The Following 2 Users Say Thank You to maxieboy For This Useful Post: |
06-20-2017, 05:55 | #10 (permalink) |
Member: 821646 Status: Offline Thanks Meter: 507 | Eeprom doesn't needs to be programmed just replaced it from a donor board and restore the phone that's it. But for Nand replacement you need to program its S/N to otiginal one before soldering it back. Hope that helps. |
The Following 3 Users Say Thank You to CDMA_RASHID For This Useful Post: |
06-20-2017, 09:21 | #11 (permalink) |
Freak Poster Join Date: Feb 2010
Member: 1247453 Status: Offline Thanks Meter: 13 | But each eeprom contains unique data on each iPhone just like the nand. Or is not it? The eeprom is changed from another iPhone without reprogramming ?, with the data that it has ?, no problem? |
The Following User Says Thank You to aries20 For This Useful Post: |
07-04-2017, 21:30 | #12 (permalink) | |
Member: 302596 Status: Offline Thanks Meter: 784 | Quote:
Question ? how do i know that the ONSEMI EEPROM damage ? when i check on power supply it seems all are okay and the other component in that case experience is must | |
The Following User Says Thank You to maxieboy For This Useful Post: |
