02-19-2017, 17:35 | #1 (permalink) |
Freak Poster Join Date: Jan 2004
Member: 48755 Status: Offline Thanks Meter: 30 | iPhone 6 goes in DFU after audio codec change I have an iPhone 6 with earpiece issue. After i checked all components (earpiece, flex, connector and filter) and all were good, i thought it was the audio codec U0900 so i replaced it and now the phone doesn't start at all. when i plug it to the computer, it takes some time then enters DFU. When I remove U0900 it starts up normally tried 3 U0900 and all gave the same thing Any idea ? |
02-20-2017, 01:21 | #2 (permalink) | |
No Life Poster Join Date: Jul 2016
Member: 2598526 Status: Offline Thanks Meter: 52 | iPhone 6 goes in DFU after audio codec change Quote:
Check the pads on PCB maybe when you replace U900 solder balls are merging | |
02-20-2017, 07:41 | #3 (permalink) |
Member: 48755 Status: Offline Thanks Meter: 30 | thats what i thought but no, each time i remove it, the solder is perfectly aligned below the chip. also U0900 has large solder point matrix. the dots are farely far from each other and cannot merge easily |
