01-28-2020, 20:38 | #2 (permalink) |
No Life Poster Join Date: Jul 2008 Location: Mumbai Age: 36
Member: 821646 Status: Offline Thanks Meter: 507 | You can change the Wifi Chip without the need to reprogram the Nand. Unbind WiFi is necessary for all PciE Nand devices. |
The Following User Says Thank You to CDMA_RASHID For This Useful Post: |
01-29-2020, 16:50 | #5 (permalink) |
No Life Poster Join Date: Mar 2007 Age: 39
Member: 475448 Status: Offline Thanks Meter: 60 | i replaced, but same. wifi mac address is missing bt is okay. have any schematic for the wifi power? i have vietmobile, but it's unuseless. |
The Following User Says Thank You to Jack_OH For This Useful Post: |
01-29-2020, 17:25 | #9 (permalink) |
Moderator Join Date: Jan 2008 Location: <jeddah al saudia> Age: 36
Member: 668050 Status: Offline Sonork: 100.1656307 Thanks Meter: 991 | what history for ipad mostly we replace ic after bypass icloud there is two types of wifi ic in ipad air 2 celular model a1567 ic is wifi+modem wifi model a1566 ic is wifi you must replace with exact model both are different number ======== |
The Following User Says Thank You to chand_gee For This Useful Post: |
02-07-2020, 12:27 | #15 (permalink) |
No Life Poster Join Date: Feb 2009 Location: inside apples a15
Member: 975554 Status: Offline Sonork: KG state:prenormal Thanks Meter: 252 | because all of the connection in center is only ground so if you reball it also it will be more difficult to melt the solder which can kill the wifi ic,,there are a lot of ground connections in pins so sometime if you know how to look in phoneboard you will more understand |
