Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 03-21-2019, 11:30   #1 (permalink)
Member: 1712908
Thanks Meter: 29
iPhone 6 impossible to activate after restoring
http://www.youtube.com/watch?v=GMGyVYFJ7AU
iPhone 6 impossible to activate after restoring to iOS 12.1.4
The Following User Says Thank You to karusa For This Useful Post:
Old 03-21-2019, 12:50   #2 (permalink)
Member: 2277735
Thanks Meter: 155
Been stolen from Apple shop, IMEI can’t be read(hardware problem)or flashed and missing something when flashed!
Old 03-21-2019, 14:29   #3 (permalink)
kimo59's Avatar
Member: 183437
Thanks Meter: 97
hello,
do exactly this :
power off the phone
put it on a hotplate during 30 min at 100 deg celcius
connect it dfunor recovery
fingers crossed and wait activation
enjoy
Best Regards.
Old 03-24-2019, 13:03   #4 (permalink)
ndagi's Avatar
Member: 18926
Sonork: ndagi
Thanks Meter: 50
Originally Posted by kimo59 View Post
hello,
do exactly this :
power off the phone
enjoy
Best Regards.
How in the world does this help????
Old 03-24-2019, 13:25   #5 (permalink)
CDMA_RASHID's Avatar
Member: 821646
Thanks Meter: 437
Connect it to 3uTool and see if it has proper S/N and BT/Wifi Mac address.
Normally the activation error occurs due to invalid S/N or Mac addresses.
You can even check if the Wifi is working or not. This might aswell cause the problem.
If invalid data is the issue. You will have to purchase gsx info from any online service and program back the required data to Nand.
Hope that helps.
The Following User Says Thank You to CDMA_RASHID For This Useful Post:
Old 03-24-2019, 18:20   #6 (permalink)
Member: 2601612
Thanks Meter: 13
If SN,IMEI,Wifi,BT adress hasn't problem, check NFC
Old 03-24-2019, 18:21   #7 (permalink)
kimo59's Avatar
Member: 183437
Thanks Meter: 97
hi,
done many times, even if it seems funny, so heat will allow you to activate the device, heat help ę*buggy*Ľ component, i used this before on many iphones with errors, you can also fix black screen on ipads 2 (no need to open to reconnect lcd ribon) this method for sure itís not a full repair so i use it to revover datas, so for activation problem itís enough to go through the problem.
I hope it will help anyone, i only share my knowledges, so try by yourself and let me know
Best Regards.
Old 03-24-2019, 20:46   #8 (permalink)
Member: 946836
Thanks Meter: 15
hello,
do exactly this :
power off the phone
enjoy
Best Regards.
LOL,,
and call or mention tim cook to activate your imei
Old 03-24-2019, 22:49   #9 (permalink)
kimo59's Avatar
Member: 183437
Thanks Meter: 97
Originally Posted by manessmann View Post
LOL,,
JakartaMan keep in mind, i didnít joke here, i already encountered this related issue and manage to bypass it many times by this method, i understand your words that it seems to be an dodgy approach so it works, donít need to call Tim cook, so cook this damn mobile.
Best Regards.
Old 03-25-2019, 15:31   #10 (permalink)
Member: 1939450
Thanks Meter: 142
It this one of the iphone 6 with a replaced NAND? in the beginning people didnt copy SN/wifi/bt data to new NAND.
Old 03-25-2019, 19:38   #11 (permalink)
Member: 1712908
Thanks Meter: 29
you're right I think this is the problem
Old 03-25-2019, 20:12   #12 (permalink)
Member: 1712908
Thanks Meter: 29
Old 03-25-2019, 20:13   #13 (permalink)
..::KASHIF::..'s Avatar
Member: 1294044
Thanks Meter: 1,233
bro buy NEw S/N and BT/Wifi Mac address
USe ip Box
The Following User Says Thank You to ..::KASHIF::.. For This Useful Post:
Old 03-25-2019, 21:24   #14 (permalink)
Member: 1388158
Thanks Meter: 22
Generated WiFi bluetooth mac address, unoriginal. Subsequently, when activating the wrong UID calculation and rejecting activation by the Apple server.
The Following User Says Thank You to Tony2323 For This Useful Post:
Old 04-01-2019, 04:51   #15 (permalink)
Member: 1298774
Sonork: 100.1584126
Thanks Meter: 84
Connect to 3utools and chose realtime log from toolbox then try activate by wifi and look in the log you will see error massge in NFC or other
I have this problem and after buy gsx wifi and bt mac address i get same info i already have in iphone so the problem bot from wifi or nand ic info , i think apple make changes t on applepay in iphone 6 all other active problem get from nfc chip
Page generated in 0.40709 seconds with 7 queries
