01-20-2017, 11:37 | #1 (permalink) |
Junior Member Join Date: Aug 2016
Member: 2611799 Status: Offline Thanks Meter: 1 | Iphone 6 no display diode d1501 burning |
01-20-2017, 13:08 | #2 (permalink) | |
Freak Poster Join Date: Jul 2008 Location: Earth
Member: 813803 Status: Offline Thanks Meter: 120 | Quote:
D1501 heating up indicates your backlight system is down.. 1.Check voltage make sure: - VCC_MAIN = 4v - PP1V8_SDRAM= 1.8V - PP1V8 = 1.8V - TEST 2.Check if any of these are shorted or damaged: - C1513 - C1552 - C1597 - C1530 - C1531 - C1505 - C2017 - C2018 - C2019 - TEST 3.Change following: - U1502 - L1503 - D1501 Let me know how it goes! | |
01-20-2017, 17:49 | #3 (permalink) |
Member: 2611799 Status: Offline Thanks Meter: 1 | I wanted to know if 190 ohm can be considered short circuit? Can a capacitor not be completely short and create a small resistance of 190 ohm? VCC_MAIN = 3.75 - 3.90 Its rise and fall - PP1V8_SDRAM= 1.8V - PP1V8 = 1.8V C1513 = 190 ohm - C1552 = 190 ohm - C1597 = 1400 ohm - C1530 = 1400 ohm - C1531 = 190 ohm - C1505 = 190 ohm - C2017 = 190 ohm - C2018 = no short - C2019 = no short - |
01-20-2017, 20:19 | #4 (permalink) | |
No Life Poster Join Date: Jul 2016
Member: 2598526 Status: Offline Thanks Meter: 52 | Quote:
Do a diode mode check with the diode removed. Positive pin on ground, negative pin on each side where diode goes. If you get a low reading <.3v drop then there's a short in the direction of the pin that measured low. If it's after the diode check the caps. One could be leaky causing a partial short. If it's before filtering caps check the ic or supply to ic | |
01-21-2017, 12:03 | #5 (permalink) | |
Freak Poster Join Date: Feb 2014
Member: 2136572 Status: Offline Sonork: 100.1653162 Thanks Meter: 41 | Quote:
Hello Dear. Having a 190 Ohms on the capacitors ( C1530, C1531, C1505) means that at least one of these capacitors is damaged, could be that is not totally shorted but it's damaged and will create an over consuming of the current which will burn the diode (D1501). Please remove the capacitors one by one and test. Thanks for Solution source ( www.tsa-mtech.co.uk ) SFS software. Sent from my iPhone using Tapatalk | |
The Following User Says Thank You to AYSER For This Useful Post: |
01-21-2017, 16:44 | #6 (permalink) |
Member: 2611799 Status: Offline Thanks Meter: 1 | I plugged a power supply with 2 volt + on most of the line pp_lcm_bl_anode and the - to ground and I put the freez bomb and the capacitor c1505 melted very quickly. Now I will replace it and re-solder the diode and I would tell you if it works |
08-13-2017, 23:34 | #7 (permalink) |
No Life Poster Join Date: Mar 2012 Location: Amsterdam, Netherlands
Member: 1732818 Status: Offline Thanks Meter: 532 | I had the same problem.. and fixed it. Your problem is almost for sure C1530 short to ground. And yes 600 Ohm shortcut means, your diode will burn too!* So just remove c1530 and your diode will not burn anymore ** |
