07-21-2015, 21:51 | #17 (permalink) |
No Life Poster Join Date: Mar 2012 Location: Amsterdam, Netherlands
Member: 1732818 Status: Offline Thanks Meter: 532 | Solution: Had the same problem today with an iphone 6.. Baseband firmware was empty in settings menu. Kept showing searching.. I have reheated the baseband ic on 400 degrees celcius with Flux for 15 seconds. Fixed the problem |
The Following User Says Thank You to HDccam For This Useful Post: |
07-28-2015, 00:24 | #20 (permalink) |
Freak Poster Join Date: Feb 2012 Location: Lebanon
Member: 1726910 Status: Offline Sonork: 100.1623945 Thanks Meter: 41 | hello i have similar case, but i ve gone too fare with trying to fix it, but no luck. iphone6 water damage cleaned, but no service. i replaced all components from the lower part of the pcb from both sides, except the baseband i reballed it. still same peoblem Sent from my iPhone using Tapatalk |
07-28-2015, 00:28 | #21 (permalink) | |
Member: 1726910 Status: Offline Sonork: 100.1623945 Thanks Meter: 41 | Quote:
forgot to mention that the modem firmware and IMEI exists in "about". software was ref-lashed but no luck Sent from my iPhone using Tapatalk | |
12-19-2015, 23:58 | #23 (permalink) |
Freak Poster Join Date: Jun 2013
Member: 1952487 Status: Offline Thanks Meter: 43 | I fixed many problems like that, usually happends after some one takes out the motherboard from its housing. I can fix that for you, contact me in pm |
The Following User Says Thank You to arvaser For This Useful Post: |
12-20-2015, 00:12 | #24 (permalink) | |
Hello Just check if you can get the imei by dialing *#06# Usually you shouldn't get any response if it is baseband problem, even if imei exists in "settings/general/about" I solved such case twice. 1st one was due to baseband pmu and the 2nd was due to tracks cut-off under baseband Sent from my iPhone using Tapatalk | |
12-22-2015, 09:25 | #27 (permalink) |
Freak Poster Join Date: May 2009 Location: kollam kerala live in riy
Member: 1031328 Status: Offline Thanks Meter: 25 | dear bro sure the 1. red screen 2. searchnig insert sim or with out sim 3. erroe 4013 [not riestoring after extracting showing apple logo then off the device ] all are same problm [ apple 338s1210] audio ic |
12-23-2015, 05:07 | #28 (permalink) | |
No Life Poster Join Date: May 2015 Location: Los Angeles
Member: 2398349 Status: Offline Thanks Meter: 62 | Quote:
Did anyone solve the problem with replacing audio ic at all?! Sent from my iPhone using Tapatalk | |
01-19-2016, 13:11 | #30 (permalink) | |
Junior Member Join Date: Dec 2014 Location: Austria
Member: 2313603 Status: Offline Thanks Meter: 2 | Quote:
Iphone 6 info showed me IMEI and firmware, but NO SERVICE But no respone on *#06# After reflow BB chip, everything is working fine! | |
The Following User Says Thank You to JakobW For This Useful Post: |
