05-26-2017, 15:31 | #1 (permalink) |
Freak Poster Join Date: Mar 2012 Location: in you are heart Age: 37
Member: 1733871 Status: Offline Sonork: 100.1627020 Thanks Meter: 28 | iphone 6 no sound we recive iphone 6 water damage i clean all pcb small audio ic is damage with water we change but still no sound speaker option is highlited on call not working speaker and ringer any one can help me who solve this problem before thanks in advance here is screen shot |
05-04-2018, 20:22 | #4 (permalink) |
Freak Poster Join Date: Sep 2011 Location: Lebanon
Member: 1657517 Status: Offline Thanks Meter: 74 | iphone 6 no sound I have also same problem iphone 6 my phone no water damege. I change audio big & small ic but same speaker hiden Please any GSM friends help me Sent from my iPhone using Tapatalk |
The Following 3 Users Say Thank You to Dulaljan For This Useful Post: |
06-26-2018, 09:01 | #6 (permalink) |
Junior Member Join Date: Oct 2004 Location: Poland, Lodz Age: 44
Member: 87864 Status: Offline Thanks Meter: 7 | check front camera flex, in iphone 7 i fix this problem many times #, i just change camera flex |
The Following User Says Thank You to kedziep For This Useful Post: |
06-27-2018, 05:31 | #7 (permalink) |
Junior Member Join Date: May 2018 Location: US
Member: 2834468 Status: Offline Thanks Meter: 5 | You can try to read these two articles: 1: How to fix a water damaged iPhone 6; 2: How to fix iPhone 6 no sound? These will give you a help! |
The Following 3 Users Say Thank You to Diven For This Useful Post: |
07-22-2018, 22:07 | #8 (permalink) |
Freak Poster Join Date: Jan 2010 Location: Canada
Member: 1211915 Status: Offline Sonork: 345634564 Thanks Meter: 93 | http://forum.gsmhosting.com/vbb/f631...100-a-2364963/ I already posted completed solution, you need to search and work hard |
The Following User Says Thank You to christina_ For This Useful Post: |
02-11-2019, 15:21 | #10 (permalink) |
Freak Poster Join Date: Nov 2017 Location: Canada
Member: 2777379 Status: Offline Thanks Meter: 34 | If you guys don't already have ZXW, buy it. Then go in iPhone 6 > Connector resistance, now find the charging connector, the resistances are diode values, compare these values to yours, it's 99% certain one or many of your values won't match to the ones on ZXW, that connection will be your problem, look what connects to it etc... To check in diode mode: red prope to ground, black probe to the pin. |
The Following User Says Thank You to 7Axis For This Useful Post: |
09-19-2020, 13:53 | #12 (permalink) |
Member: 1657517 Status: Offline Thanks Meter: 74 | iphone 6 no sound Final Solution, iphone after water damage or audio sound problem. after change ic audio same problem —> just change charging flex rabon or disconnect Headphones jack port and Enjoy. I was tested many iPhone Sent from my iPhone using Tapatalk |
12-11-2020, 07:43 | #13 (permalink) |
Crazy Poster Join Date: Jul 2020 Location: China Age: 25
Member: 2964041 Status: Offline Thanks Meter: 3 | Well, here I will recommend an ios recovery tool for you. No matter you meet with water damaged iPhone, no sound on iPhone, or any other iOS issues happened on other iOS devices such as iPad and iPod, you could fix it through TunesKit iOS System Repair. |
