Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 01-13-2018, 00:57   #1 (permalink)
Member: 2343716
Thanks Meter: 8
Iphone 6 no video after touch ic repair
Hi. I have iphone 6 with touch problems.
Reballed touch ic and then no video, backlight working, phone turns on and connects to iTunes , rings and all.
Reballed touch ic again, replaced it and still same.
I have checked all filters, reflow video ic but no luck.
Can anyone point me on the right direction?
Thanks
Old 01-13-2018, 06:21   #2 (permalink)
Member: 2777379
Thanks Meter: 34
Touch IC shouldn't cause no display, try booting with Touch IC off the board.
Old 01-13-2018, 15:41   #3 (permalink)
Member: 1295004
Sonork: 100.1610057
Thanks Meter: 29
or you floated chestnut on the other side
Old 01-16-2018, 18:32   #4 (permalink)
Member: 2343716
Thanks Meter: 8
Replaced chestnut. Still same.
Old 01-17-2018, 14:29   #5 (permalink)
Member: 2777379
Thanks Meter: 34
If it was working prior to reballing the Touch IC you definitely messed something up by using too much heat or your reball was bad, the new Touch IC could be bad also, check for shorts around, and like I said try with the Touch IC off the board, there are display traces/nets going through the Touch IC, the chip is not needed for display however if it's shorted it may cause display issue.
Old 01-27-2018, 16:10   #6 (permalink)
Member: 2343716
Thanks Meter: 8
Working fine with touch ic out. Just no touch... will try another ic then
Old 01-27-2018, 23:22   #7 (permalink)
Member: 2753739
Thanks Meter: 7
If the display works when you remove the mason ic that mean the traces not connected correctly or melt some traces together OR wrong orientation OR bad IC
Page generated in 0.13477 seconds with 8 queries
