Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 02-19-2018, 23:24   #1 (permalink)
Member: 1696994
Thanks Meter: 24
iPhone 6 plus audio random issue
We have an iphone 6 plus.
It had touch disease, reballed meson and all ok, after 1 week customer returned, no external sound but earspeaker and mic on, no volume buttons working, also no service.
Reballed BB ic and received vodafone signal, audio too but then it went odd.
If phone is been used then volume buttons and audio work, if screen off and woken up, no audio again for say 6 or so secs.
Reballed large audio ic, replaced small audio ic, its very much the same although not every time, any thoughts
Old 02-28-2018, 19:52   #2 (permalink)
Member: 1696994
Thanks Meter: 24
No thoughts, prior to this had reballed baseband
Old 03-01-2018, 20:34   #3 (permalink)
Member: 1696994
Thanks Meter: 24
Have changed both audio ics about 4 times, still no audio on loudspeaker, earspeaker and mic are fine, when I pres the volume buttons, nothing, mute switches on and off fine but no loud speaker sound....help
Old 03-05-2018, 21:38   #4 (permalink)
Crazy Poster
Member: 7187
Thanks Meter: 12
Have You tried with headset how it works the audio part ?
Old 04-23-2018, 17:07   #5 (permalink)
Member: 1696994
Thanks Meter: 24
when I press volume buttons with headset in it shows headphones and volume increasing or decreasing.
Without headset plugged in, just shows ringer and no volume bars
Old 04-23-2018, 17:56   #6 (permalink)
mobileunlockers's Avatar
Member: 396778
Thanks Meter: 155
check for short caps around the audio IC's. Also put some pressure on the cpu if its work. if it does then you have to reball the CPU. Also there is a link between u2 ic, Baseband IC and audio IC.
Old 05-27-2019, 18:40   #7 (permalink)
CellM@n's Avatar
Member: 3194
Thanks Meter: 41
i have this problem too,
change flex and audio ic's still same.
anyone have solution pls help.
Page generated in 0.24151 seconds with 8 queries
