Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 10-23-2017, 16:40   #1 (permalink)
cod3r's Avatar
Member: 1613754
Sonork: 1623976
Thanks Meter: 115
iPhone 6 Plus fake charging
Hi,
iPhone 6 Plus fake charging, stuck on 5%.
I'm change u1700 (u2 ic), U1401 and Q1403. change new battery, flat for charging. and same problem.
Voltage is ok.
The Following 2 Users Say Thank You to cod3r For This Useful Post:
Old 10-24-2017, 09:58   #2 (permalink)
Member: 2720825
Have you checked for full/partial shorts to ground on the common failure points? (VCC_MAIN for example)
Old 10-26-2017, 00:04   #3 (permalink)
cod3r's Avatar
Member: 1613754
Sonork: 1623976
Thanks Meter: 115
No short circuit found.
The Following User Says Thank You to cod3r For This Useful Post:
Old 10-26-2017, 04:36   #4 (permalink)
Member: 2226403
Thanks Meter: 32
Check the battery bsi point
The Following User Says Thank You to gsm-raj For This Useful Post:
Old 10-26-2017, 13:01   #5 (permalink)
orx
orx's Avatar
Member: 1825965
Thanks Meter: 874
check image
The Following 2 Users Say Thank You to orx For This Useful Post:
Old 10-26-2017, 18:58   #6 (permalink)
cod3r's Avatar
Member: 1613754
Sonork: 1623976
Thanks Meter: 115
I did it, the same problem. thnx for answer.
Old 10-27-2017, 16:33   #7 (permalink)
cod3r's Avatar
Member: 1613754
Sonork: 1623976
Thanks Meter: 115
LCD on fake charging, on standby (black screen) 0amp.
Old 12-09-2017, 21:06   #8 (permalink)
Crazy Poster
Member: 189861
Thanks Meter: 14
i have same 100% problem ....... :@:@:@:@ im change all part charge 0amp..
Old 04-23-2018, 23:51   #9 (permalink)
Member: 2830806
Iphone 6plus fake charging solution
Bro remove the feuse near the charging ic
And make jumper
Old 04-24-2018, 01:41   #10 (permalink)
Member: 2383669
Thanks Meter: 10
it is a CPU damage you need to connect 2r (2.2k)to first line of trigis ic
this issue is common on iphone 6 and 6 plus
The Following User Says Thank You to MoazMod For This Useful Post:
Old 05-14-2018, 10:34   #11 (permalink)
XxTQxX's Avatar
Member: 1068286
Thanks Meter: 182
i have same problem LCD on phone charging, on standby (black screen) 0amp after change U1401 work
The Following User Says Thank You to XxTQxX For This Useful Post:
Old 09-17-2018, 23:21   #12 (permalink)
Member: 1169582
Sonork: oghianos
Hello friend . I have this problem with iphone 6
. Please help us to solve 🌹
The Following User Says Thank You to oghianos mobile For This Useful Post:
Old 10-31-2018, 20:46   #13 (permalink)
Registered User
BouRRi_GSM's Avatar
Member: 111457
Thanks Meter: 967
Hello
Can u explain more.
The Following User Says Thank You to BouRRi_GSM For This Useful Post:
Old 11-01-2018, 11:10   #14 (permalink)
ninos22's Avatar
Member: 1903358
Thanks Meter: 146
Originally Posted by BouRRi_GSM View Post
Hello
Can u explain more.
If battery percentage is 1% always, CPU damage drops current from BATT_SWI (1,8v)
So if there is no 1,8v in this line you have to pull up current by connecting 3V0_TRISTAR with 2.2k resistor to the BATT_SWI line.
The Following User Says Thank You to ninos22 For This Useful Post:
Old 03-04-2019, 18:40   #15 (permalink)
Registered User
Member: 777512
Sonork: zOOm25
Thanks Meter: 9
how to do this sir? help please!
The Following User Says Thank You to zOOm25 For This Useful Post:
Page generated in 0.20953 seconds with 9 queries
