Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 10-16-2015, 21:39   #1 (permalink)
Member: 453077
Iphone 6 Plus front camera and earpice stoped working
I have a 6 plus that had problems with the back camera, i replaced it and now its fine but the front camera and earpice stoped working!
Its not the front camera flex, i replaced it multiple times for new ones, i even repleced complete display with all the flex from a working 6 plus and no luck...
And mainboard becomes very hot after some minutes...
Conector seems ok... PLEASE HELP
Old 10-17-2015, 10:00   #2 (permalink)
HDccam's Avatar
Member: 1732818
Thanks Meter: 532
image search
Change the front flex cable first!
Specially when the phone gets hot at the top.
If that didnt solve your problem, Then Check the RED marked points for your missing ear audio.
Check the YELLOW marked points for the front camera.
There are more points to check, but these points are easy to damage.
Jumper the filters or replace them if missing.
Old 01-04-2016, 10:26   #3 (permalink)
Member: 2130936
i was jumper two FL1123 and F1144 but the front camera remains inactive.
Are there other ways to help her only
Old 02-14-2016, 19:48   #4 (permalink)
Member: 201211
If you didn t solve your problem OF FRONT CAMERA,
check FL1112, FL1113, FL1114, FL1115,
IT S WORK FOR ME
Old 07-15-2016, 09:37   #5 (permalink)
Member: 2598645
hi Everyone
I just changed broken lcd to oem Apple lcd. Then earpiece and front camera didn't work, so I changed flex cable. Earpiece now works but the front camera still don't work. so do you guys think checking yellow circles from hdccam reply and fl111x components from smangsm reply? I have a cheap $5 multimeter. how do I use this to check. I only know how use ohms meter function. pls help me step by step with multimeter. I took high school electronics and can repair components like fuses, resisters, capacitors, jumpers and broken traces with ohm meter. thank you all
The Following User Says Thank You to Nipsta For This Useful Post:
Old 07-15-2016, 11:29   #6 (permalink)
Member: 2598645
Okay guys, so I googled fl1111, fl1112, etc. it says it's resisters at 120ohm. Is this correct? If I find a bad resister, where do I find the replacement? Please advise. Thanks in advance.
Old 02-28-2017, 14:52   #7 (permalink)
Member: 209734
Thanks Meter: 3
thanks for the info bros
Page generated in 0.12656 seconds with 9 queries
